Cj Kumz Posted November 24, 2014 Author Report Posted November 24, 2014 Could someone please verify if that minimum port area calculation is for any box size. In our hdc3 example will that port area be the same in a 3, 4 and 5 cube box Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
alaskanzx5 Posted November 24, 2014 Report Posted November 24, 2014 Would it be safe to assume that with more box volume you can use a slightly smaller amount of port area? I mean you need pressure inside the box for cone control. A big no with a big port gives less control. A big box with a say a 10% smaller port could give a little bit more pressure inside the chamber. Just a theory here. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Joe X Posted November 24, 2014 Report Posted November 24, 2014 I guess I understand what you are trying to say, the Small's estimate is based on the mechanical displacement of the sub (+ tuning) and will work under any box size, power, etc. It's true however everything else being equal larger net volume result in larger peak excursion so Small's estimate is a one size fits all and in many applications is space inefficient or plain not feasible.
Cj Kumz Posted November 24, 2014 Author Report Posted November 24, 2014 Thanks a lot. I really needed that cleared up. Ok so do you guys think its worth it to build a new enclosure for my hdc315. Currently in a 4 cube box @ 36hz with 64sq inches. Calculator shows I need above 100 sq inches Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
Triticum Agricolam Posted November 24, 2014 Report Posted November 24, 2014 Thanks a lot. I really needed that cleared up. Ok so do you guys think its worth it to build a new enclosure for my hdc315. Currently in a 4 cube box @ 36hz with 64sq inches. Calculator shows I need above 100 sq inches Are you using the SAZ-3500d in your sig to power it? I don't know if it would be worth it or not. I guess it depends on how much you like to build boxes. If it were me I would build it, just to see the difference it makes, but I like to build stuff. If you are putting all 3500 watts or moe into that thing I think you will see some benefit, but I don't think it will be a dramatic difference. If you aren't using all the power, you probably won't see much difference. Also to comment on what alaskanzx5 and JoeX said. On larger boxes, if anything, you would want a slight larger port since you have a larger volume of air that is being manipulated to move in and out that port. By making the port smaller to try to gain cone control you are relying on air resistance, which is not what gives ported boxes cone control. Cone control comes from the air spring effect you get from the mass of air inside the port. If you made the port smaller I think you would just run into port compression, which would restrict cone movement, but would kill output. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jessica Posted November 24, 2014 Report Posted November 24, 2014 I don't understand how power is a factor. I mean if you build a larger port because you have more power how will the box perform at lower volume. If you are building a box for pure SPL I think it would make sense. Someone want to explain this? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
la negra Posted November 24, 2014 Report Posted November 24, 2014 I am under the influence that the port area of 9-10 will be more musical setup and 11-12 for spl numbers .
CleanSierra Posted November 24, 2014 Report Posted November 24, 2014 I am under the influence that the port area of 9-10 will be more musical setup and 11-12 for spl numbers . You're under the wrong impression then. You satisfy the driver's needs(cone area and Xmax), as well as desired tuning frequency. You guys are over thinking this box volume to port area ratio. All you're doing is effectively tuning a plug of airspace, simple as that. Im not the one you want to try to troll. Just a fyi for you.
Cj Kumz Posted November 24, 2014 Author Report Posted November 24, 2014 Thanks a lot. I really needed that cleared up. Ok so do you guys think its worth it to build a new enclosure for my hdc315. Currently in a 4 cube box @ 36hz with 64sq inches. Calculator shows I need above 100 sq inchesAre you using the SAZ-3500d in your sig to power it?I don't know if it would be worth it or not. I guess it depends on how much you like to build boxes. If it were me I would build it, just to see the difference it makes, but I like to build stuff. If you are putting all 3500 watts or moe into that thing I think you will see some benefit, but I don't think it will be a dramatic difference. If you aren't using all the power, you probably won't see much difference. Also to comment on what alaskanzx5 and JoeX said. On larger boxes, if anything, you would want a slight larger port since you have a larger volume of air that is being manipulated to move in and out that port. By making the port smaller to try to gain cone control you are relying on air resistance, which is not what gives ported boxes cone control. Cone control comes from the air spring effect you get from the mass of air inside the port. If you made the port smaller I think you would just run into port compression, which would restrict cone movement, but would kill output. Thanks for that great info. I seem to be getting your point. I'm actually running my saz-3500d @ 2ohms(dual 1ohm sub) so that's about 2000w but 800w after rise. On Saturday I tried it at 0.5ohms and it sounded amazing but like air flow was restricted. So with your info my experience kinda makes sense. I should be getting another 15 when I get a bigger car (had to sell my other cause I eliminated the backseat and my wife wasn't too happy with that lol), but I'll definately work on a bigger port. Thanks again Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
Triticum Agricolam Posted November 24, 2014 Report Posted November 24, 2014 No problem, glad I could help! "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
