Port Area Clarification
Cj Kumz
Ok so we all know the general rule for aero ports is 9-12sq inches per cube and slot ports is 12-16sq inches per cube right. And we also know that Xmax, cone area and tuning frequency will affect port area.
So in two examples lets look at an AQ HDC3 15 which has an Xmax of 36mm and we want to tune to 35hz in a 4 cube box.
AQ suggests 64sq inches of port for a 4 cube box as you can see above. That's example 1.
Then according to the Xmax theory a 4 cube box at 35hz will require a port area of 131sq inches which is 32.75sq inches per cube as shown above.
So what method do you box builders use? And what are your reasons?
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
So like many things, reality is more complex than what the formulas can tell you. The vent calculator you used in your second example is based on keeping port velocity down at a fairly conservative speed. It also assumes you will be pushing the sub to its limits in terms of extension, both these things result in it giving you a pretty big number. If you were to use this number you would certainly be fine and wouldn't have any port velocity problems. What you would also have is a huge port, that is a mile long, which can have its own set of issues.
It has been my experience that if you round over all the edges of the port and use generous flares you can get away with port area that's around 75% of what the port area calculator tells you. Another thing to factor is how much power you are going to be pushing to the sub. If you only put RMS power to that HDC15 you can use a lot less port than if you are going to through 4K at it. WinISD can be a good tool for helping you determine how power is going to effect port velocities. Lower port velocities are always better, but I try to keep things at or below the high 20's m/sec.
So using the HDC15 example I would probably shoot for a port in the 90 sq in area.
Builds:
Meh, i threw away that ratio after talking with Singer and Butler like a yr ago. They both recommend me with a 4" aero and 2-2.1 cube box... which comes out to 5.9sqin/cube.
Then.. To test.. I did (2) 3" ports in 2.1 subs, which was closer to the "ratio" at 6.7sqin/cube.
Guess what box performed better..
Sure, application matters.. But this opened my eyes..
On top of that, I started modeling my port/vent velocity for those boxes, along with friends'.. and did some reading.. I saw a common theme.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Thanks a lot. So in general the box size won't affect how much port area you use? Like the 90sq in would that be the same for a 3, 4 and 5 cube box with the same sub? Currently I have an hdc315 in a 4 cube box with about 64sq inches and considering a box change
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Ok so the main issue when designing a box is velocity? As long as its undercontrol then we safe
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Count the number of fingers and toes you have, keep the velocity below the amount of those added together in meters per second.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Anyone know a good port velocity calc?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Any modeling software will do but the results are theoretical as usually assume there are no losses, the better way to know is to measure it.
How do you measure it?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Hot wire anemometer is the best way. Not a really common tool unfortunately.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 5432 Guests (See full list)
