Connecting 5 channel amp to 4 channel deck
Kade
Pioneer FH-X700BT has a front RCA out and switchable sub/rear out. I want to maintain all 4 channels for balance and fading, but want to add a sub with the use of a 5 channel amp. What are my options?
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
The amp can probably work on front and rear inputs only. But unless you have some external sound processor you aren't getting balance and fade and sub from front/rear RCAs.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
most 5 channel amps take 4 channels of input and split off the rear to get the 5th channel input. So unless the 5 channel amp you have accepts front rear sub inputs you may not have control of the sub output. There may be some 5 channel amps out there that have a "bass" knob buy i don't know of any off the top of my head.
The best answer though is to get full use out of the 6 channels of output your radio has is make sure you have 6 channels of amplifier input. 3 two channels, 1 four channel and one two channel, Two 2 channels 1 mono block...... you get the picture
Rolex you sicken me.
Just let me finish my pie
~ Juice
He only had 4 channels of output from his radio. no way he can do a 5 channel amp and retain the use of fade/balance without affecting the sub channel.
F150:
Stock :(
Processor: DSR1
The amp I had picked out has 6 channel inputs with bass knob control. I see what you're saying in your second paragraph, but I only have 4 RCA outs. 2 of them function as sub OR rear. I can't use 6 channels all at once.
Now that I think about it, when I fade and balace with a cable splitter installed, the sub output of the amp would be affected, wouldn't it?
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
if he splits the rear channel, the sub is affected by the fade/balance though. That is what he is trying to avoid. He can't avoid that using that amp and headunit.
F150:
Stock :(
Processor: DSR1
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 1154 Guests (See full list)
