U talking about T/S specs.. or like TL?
If T/S.. The specs are on Sundown's site.
If the TL, then LOL
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
no vs thread u prolly get shut down like my 6 10s benefits over 1 18 thread got locked
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
I didnt realize you had these badges..
LMFAO so true
:blush:
What is TL?
I'm asking about maximum output capabilities. Sorry, didn't realize SPL could also mean sensitivity.
Seriously? No vs threads? That would cut out a lot of discussion. But this is a legitimate question that I think there is a definite and quick answer to.
Edited by bcodemz
TL = TermLab
TermLab measures decibels (which is what I think you want).
If you could fit an 18 PROPERLY with the recommended airspace, port area, and tuning.. id go for more cone area.
However, if the 18 is in an undersized box, being choked on port area.. the 15 would most likely be louder.
You should do some reading :good:
LMFAO so true
:blush:
TL = TermLab
Yes, this is what I want.
I'm wondering in optimally sized boxes, how much more extra output the 18 is able to put out over the 15.
For me, both subs will be undersized. Think 16'' cube for the 15'' and 19'' cube for the 18''. I know it is not optimal, but size is pretty important. I'll try to mitigate as many problems as I can by throwing power and using EQ.
This is for home use BTW, not for a car. I'd love to use an 18'' Zv4, especially when it is only like $20 more than the 15. If I could easily live with the size, then the 18'' is a no brainer. But, size is important.
Edited by bcodemz
TL = TermLab
If you are planning on running either sub in an undersized box you will probably be dissapointed. If you can't fit a 15 properly then I would just go for a 12. It is one of those things that you are spending more money for a sub that is built capable to reach a higher output, but if you don't supply it with what it needs to reach that output then you are just wasting your money and potentially harming your equipment. Do some reading. Do a lot of measuring. See what you can practically fit, and go from there.
Also if by EQ you mean boosting the lower frequencies. You need to be very careful. It is very easy to introduce clipping, and you can easily fry your woofers.
Also like stated above, this site has a clear rule about vs. threads. Good potential this is going to get locked up by a mod.
Edited by MrBigs63'
in for the butt hurt. :peepwall:
pretty sure this thread question was already answered!
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
You can have vs threads as long as its the same company [or so i heard] like fi sp4 vs team or dc level 6 vs xl
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
