Sundown SA-15 Enclosure Ideas?
EraOfDiscovery
I'm looking to buy 2 Sundown SA-15 D2's and I was looking for some box ideas that people have had good success with? I drive a 03 Chevy Tahoe, currently running 2 Alpine SWR-12D2's in a sealed box with 1.76 cubic feet per chamber and 2 Pioneer GM-D8601 ampilifers. I will be running the Sundown off of the same amps so I will be feeding them 800rms a piece. I would like the box to be tuned to around 32hz for SQ and was planning on using a 6 inch areoport, but not sure if one will be enough. The only other request I have is the box be 47/48 inches wide for a nice fit in the back of my truck. Open to any ideas! Thanks! -EraOfDiscovery
-Just trying to make the world a louder place, one decibel at a time...
Well my friend you will need way more than a single 6" areoport for a pair of 15s
As for a box get us Ur max dimensions..
I figured that I was going to hear that about the port lol as for the dimensions, 48" wide, 48" deep, 40" tall.
For my last enclosure for a single SA-15 we designed the port to have 64 sq inches.
It'll be over Christmas break when we get to finish the build.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
48" wide
24" deep
18" tall
With 4 6" aeroports (?)
32"long 32hz
With .5 cubes (estimated for 2 subs) displacement you will end up with a tuning of 32.26
A net volume of 7.18
And 15.75 inches of port per cube..
Rough box... I've never ran a sa-15 befoe.. should be close..
Also Idk if u could use 8" areos might be better Bcs u would only need 2
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 7 3/4", figure is just an assembly guide:
I was waiting for you to chime in ?
One day I hope to be half as good of a box designer as you...
  • Who's Online   0 Members, 0 Anonymous, 346 Guests (See full list)
