Triticum Agricolam Posted December 14, 2014 Report Posted December 14, 2014 I can't seem to get my enclosure port velocity below 30 m/s. I'll most likely be getting (90% sure of it) that I'll order a Fi BL 10" subwoofer. Do you think you can help me Triticum? Sure, if I can. Though lowering port velocity is a pretty straight forward thing, just make the port bigger. Fitting that larger port into the box is the tricky part. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Omega5002 Posted December 14, 2014 Report Posted December 14, 2014 Port per cube needs to die. I'm sigging this lol 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
mrazandrewm Posted December 15, 2014 Author Report Posted December 15, 2014 I can't seem to get my enclosure port velocity below 30 m/s. I'll most likely be getting (90% sure of it) that I'll order a Fi BL 10" subwoofer. Do you think you can help me Triticum? Sure, if I can. Though lowering port velocity is a pretty straight forward thing, just make the port bigger. Fitting that larger port into the box is the tricky part. I have a design that I want you to look at (if you want) and tell me if it'll work or not. I also, would like some help in determining how to bend wood to make a flared port. I'll post the design up soon. Just doing the finishing touches. Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4 BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit Headunit: Stock (Leaving factory look) Speakers: Stock Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches) Amplifier(s): Sundown Audio SAE1000.1D Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
mrazandrewm Posted December 15, 2014 Author Report Posted December 15, 2014 Here's a picture of the design I was thinking of doing. It's 1 Ft^3 tuned to about 32 Hz. The port is 6" x 3". Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4 BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit Headunit: Stock (Leaving factory look) Speakers: Stock Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches) Amplifier(s): Sundown Audio SAE1000.1D Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
Joe X Posted December 15, 2014 Report Posted December 15, 2014 Well, that brace looks almost like a problem, something lighter would be more than enough.
kirill007 Posted December 15, 2014 Report Posted December 15, 2014 I like 20m/s, atleast you know for sure Guess I'm good to go, my minimum is 15.02. But anyways OP, have you tried that and checked your port area off of Krakin's links? Minimum? It's supposed to be maximum. I'm not looking for port area. I know how much port area I need. I just want to know the velocity that it needs to stay under. Port area is directly related to air velocity. Thinking is the root of all problems... You ALWAYS get what you pay for.
Triticum Agricolam Posted December 15, 2014 Report Posted December 15, 2014 Well, that brace looks almost like a problem, something lighter would be more than enough. X 2. I like where that brace is, but I would simplify it significantly. Can you post a link to your sketchup file? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
SQL50 Posted December 16, 2014 Report Posted December 16, 2014 I had zero port noise OP, worked out great.
mrazandrewm Posted December 16, 2014 Author Report Posted December 16, 2014 Well, that brace looks almost like a problem, something lighter would be more than enough. X 2. I like where that brace is, but I would simplify it significantly. Can you post a link to your sketchup file? How would I go about posting my sketchup file on here? Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4 BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit Headunit: Stock (Leaving factory look) Speakers: Stock Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches) Amplifier(s): Sundown Audio SAE1000.1D Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
mrazandrewm Posted December 16, 2014 Author Report Posted December 16, 2014 Brace option #1 Brace option #2 Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4 BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit Headunit: Stock (Leaving factory look) Speakers: Stock Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches) Amplifier(s): Sundown Audio SAE1000.1D Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
