mrdavebasshead75 Posted December 18, 2014 Author Report Posted December 18, 2014 Is there anything aftermarket that would mess with the wiring; like an alarm? Bone stock!! http://www.stevemeadedesigns.com/board/topic/141026-2001-bravada-build-2-15supdated/?fromsearch=1 ----old build!! http://www.stevemeadedesigns.com/board/topic/194247-2005-chrysler-300c-buildslowwwww-lol/ -----new build!!
bentandbroken Posted December 18, 2014 Report Posted December 18, 2014 Along with checking fuses, Check out issues with the Body Control Module (sometimes called the front control module). It controls alot of those functions and many more. I havent dealt with a 300C specifically, but i have seen some really strange electrical gremlins occur when there is an issue with the BCM or related fusing and wires. Research that a little more. Life's a trip. . . Don't fall.
Masterbasser Posted December 18, 2014 Report Posted December 18, 2014 some states require dealerships to provide warranties covering any issue for a certain amount of time Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
bentandbroken Posted December 18, 2014 Report Posted December 18, 2014 I should also mention that if you find that no fuses are bad, a bulb thats shorting or a switch the controls them may be bad. I know this is also basic, but have you had the battery tested? Life's a trip. . . Don't fall.
Broke_Audio_Addict Posted December 18, 2014 Report Posted December 18, 2014 How long ago did you buy the car? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
mrdavebasshead75 Posted December 18, 2014 Author Report Posted December 18, 2014 I should also mention that if you find that no fuses are bad, a bulb thats shorting or a switch the controls them may be bad. I know this is also basic, but have you had the battery tested? going to get the bat tested today!! http://www.stevemeadedesigns.com/board/topic/141026-2001-bravada-build-2-15supdated/?fromsearch=1 ----old build!! http://www.stevemeadedesigns.com/board/topic/194247-2005-chrysler-300c-buildslowwwww-lol/ -----new build!!
mrdavebasshead75 Posted December 18, 2014 Author Report Posted December 18, 2014 How long ago did you buy the car? bought the car 3 weeks ago! Everything worked fine until a couple of days ago! Got pulled over last night because my lights kept cutting off!! http://www.stevemeadedesigns.com/board/topic/141026-2001-bravada-build-2-15supdated/?fromsearch=1 ----old build!! http://www.stevemeadedesigns.com/board/topic/194247-2005-chrysler-300c-buildslowwwww-lol/ -----new build!!
Broke_Audio_Addict Posted December 18, 2014 Report Posted December 18, 2014 Take it back tell them either fix it or you'll call a lawyer. Most states have laws to protect you from shady dealers. I'll bet money it's a flood car. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
bentandbroken Posted December 18, 2014 Report Posted December 18, 2014 After a bit of research and Online forum digging, I seems like what the OP is experiencing is a fairly common issue for the 300c and Charger. The primary complaint was that in the winter these electrical issues start cropping up. Apparently the electrical system In the 300c is very sensitive to changes so in the winter if the battery is already weak the cold weather is enough to start causing these issues. They said that once the weather warmed up the symptoms lessened or disappeared completely. The Solution was a new battery in most cases, however there were a few instances where there was a partially burnt bulb, bad BCM (or FCM), bad switch on the dash for lights (almost any light) or blinker. I didnt see any cases resolved by fixing wire shorts, fuses, or the headlight control module, but those were also suggested culprits. Personally, I would check to make sure your battery terminals and grounds were all tight. Or if the battery has corrosion. Hope this helps! Life's a trip. . . Don't fall.
SIDE SHOW Posted December 19, 2014 Report Posted December 19, 2014 take it back to the dealer..........
