Ok guys need some insight on what I wanna do. I got 2 15's in the trunk (re se x) kenwood rears and infinity in the front. I want to make a center console box for my buick lesabre and put a skar ma 8 in for more spl good idea or bad ? I dont wana change nothing in the trunk just want to know if it would be ok or not to add the 8" woofer in the center console
Its not the best idea to mix subs, Then it wouldnt sound as good as it could be, Maybe if you put it on the right crossover so it only hits something like 80-150hz and the 15's hit 20-80.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Using it as adding more sub bass won't do anything, but if you intend to use it as midbass then you'll gain the missing part most systems lack between the sub and sound stage. You will need a pair and have them fire into each side of the car for best effect as midbass is directional unlike the sub stage.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
go out and get 2 mid woofers. you can do the same thing your thinking of. i would do a sealed box and run them at 50-550hz then cross the mids in your doors at 500hz And so on. you'll be surprised how much better real mid woofers will sound then that sub.
plus i don't like putting over 120hz to any sub.
not to mention you can get 2 prv 4ohm 8inch mids for about $60 bucks. so with your budget of $130 you can spend $70 bucks on a nice 2 channel amp to power them if you don't have one already.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
