Fuse Question
I have two dc 3.5s and I wanna know if I fused them properly. I added the dual 1/0awg inputs to each of them so a total of 4 power wired going from amps to bus bar and I fused each of those with 150 amp fuse... is this correct? also I put the 1/0 awg ground inputs in also but only had enough wire to run one ground to each amp, could this cause any problems having two power and only one ground?
You fuse for your current demands not the wires rating, you should use the smallest fuse you can.
  • Who's Online   0 Members, 0 Anonymous, 3537 Guests (See full list)
