hdorre Posted December 24, 2014 Report Posted December 24, 2014 ^^ What n8 said lol.. I just used Spax #14 multi material construction screws. They were like 2 1/2" long.. that or 2 1/4" On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Kyblack76 Posted December 24, 2014 Report Posted December 24, 2014 Thanks. Some of us have "been around". Weve heard of "extra steps" No thanks. I'll stick with god deck screws. Nothing more. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Revdoc Posted December 26, 2014 Author Report Posted December 26, 2014 For those who say it's overcomplicated, you're probably right. Screws would have worked fine. I appreciate the sentiment as a "KISS" type of person, but I'm already started down this rabbit hole so lets see how it ends up. Do yourself a favor if you do this, use a drill press or at least a piece of MDF with a pre-drilled hole as a guide to keep your holes square with the baffle. I didn't and my studs all tilt slightly upward, no big deal as you won't see them and the sub still drops into place without binding. I used a stack of a nut, washer, then another nut to install these. Put a small socket on the outermost nut and turn it against the washer, it will drive the screw in. Then a sharp tap on the wrench will loosen just the nut and you can put the nut/washer/nut setup on the next stud for install. http://i.imgur.com/T8FwmWf.jpg With the sub sitting in the baffle: http://i.imgur.com/srdp0Pt.jpg Another tip: measure the holes in the basket of the sub before you purchase hardware. I bought 5/16 outer dia. spacers and find out that the PSi basket has a 5/16 screw hole, spacers fall right through them. Luckily I had some #10 washers that fit. The bits referenced by Triticum were helpful, I found a Kobalt version at Lowes but it was called a "hinge bit" for installing door hinges. Also, I think I will try to skip the spacer and put the nut and washer directly on the rim of the sub, under the rubber gasket. The only problem will be pulling the rubber gasket up over the stud to hide it after installing the nut and washer, I hope I don't tear the gasket. PS: please keep ridicule about the box polite, I am sensitive
jakmagic Posted December 27, 2014 Report Posted December 27, 2014 I was recommended SPAX screws and until I come across something better, those are all that I will use. The threads are very aggressive and not spaced too close together. They are just like deck screws but more aggressive. AJ a member on here recommended them to me and until something better comes out, those are the ones for me. 97 Buick LeSabre with stock 140 amp alternator XS Power D3400 (under the hood) using pdb distro blocks Big 3 done with 2/0 ga welding cable Alpine CDE-HD149BT head unit CT Sounds Meso 6.5" components CT Sounds 60.4 CT Sounds 1400.1 Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs) Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders) Connection BT2 & BT4 550 (Audison) RCA's Bunch of Mojo Mat
alaskanzx5 Posted December 27, 2014 Report Posted December 27, 2014 I've used those exact same bolts before op. I work at a car audio/furniture store. The Amish (yeah we all know the truth) use those to hold a good portion of the table tops on. And keys just say that the bases get heavy and those books hold up just fine. They did fishery to put in at one point. I used 2 nuts to screw it in ( locked the nuts up against each other ). Worked just fine. To get the extra but of put a wrench on birth and turn them away from each other. A truck I've seen with t nuts is to put a short word screw on the edge of each one. Holds them right down in place. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Revdoc Posted January 2, 2015 Author Report Posted January 2, 2015 Ok, subs are mounted and the box is in the car. Sounds okay for now, can't wait to get the XS Power D925s I have ordered and hook up the AQ 3500D.1. I'm currently powering them with an Audiopipe 1800 and they barely move. Some more pics of the spacers installed and then the sub mounted with nuts and everything: http://imgur.com/a/kXmHU I ended up using 3/8" steel spacers from Lowes, they were zinc plated and nice looking. They only had 11 in stock so I had to get 5 more at Ace Hardware, these were raw steel finish and were not solid all the way around. I'll replace them with the nice ones from Lowes when I get a chance. I had to drill out the rubber gasket on the subs to make it fit these larger spacers but it looks pretty good when it's all mounted up, the washer covers any small imperfections in the rubber gasket. If I had installed my studs nice and square I think my setup would look perfect, as is I'm okay with it.
