sicrides6 Posted December 27, 2014 Report Posted December 27, 2014 What part of it are you worried about and what size amps
sicrides6 Posted December 27, 2014 Report Posted December 27, 2014 First thing id change is big 3 included plus add another battery or two or three depending on size of amps and up graded alt
rockFord_Expedition Posted December 27, 2014 Report Posted December 27, 2014 Ditch the bass knob Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
islandpride684 Posted December 27, 2014 Report Posted December 27, 2014 Does your HU have a sub-out? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
redwolf2 Posted December 27, 2014 Report Posted December 27, 2014 Ditch the bass knob Why? Also, it's hard to understand what you're asking. If you're going to run 2 amps off 1 power wire (with a distribution block like in the drawing) you need to make sure you're taking into consideration both amps combined draw. Other than that it seems to be fairly correct (minus the fault in the drawing with the sub Amp running off the speaker amp for RCAs) although you might find you're better off doing 2 separate runs of power wire (I have a very similar setup, running mono off 0 gauge and the 4 chan off 4 gauge) What amps? What deck? What vehicle?
Broke_Audio_Addict Posted December 27, 2014 Report Posted December 27, 2014 Ditch the bass know because all it does it boost a specific frequency potentially introducing clipping or distortion. well on some amps you can adjust the frequency it boost but still it's boosting something which is not needed. This is assuming it's the factory bass knob and not something like a pac lc-1 which is fine to use. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Masterbasser Posted December 27, 2014 Report Posted December 27, 2014 nothing wrong with having a bass knob, i usually always ran mine at no boost, but when certain songs come on (older songs in general for example some beastie boys songs) its nice to be able to turn up the bass a bit if its lacking from the recording, yea it adds distortion but dont need to go overboard with it. Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
jakmagic Posted December 28, 2014 Report Posted December 28, 2014 The only reason I like my bass nob, is the digital voltage meter that comes on it and having the ability of turning off my sub amp from the driver seat. I know that not all bass knob volt meters are very accurate but I also have one on my dash board and they usually read the same voltage. Kinda like having a backup. 97 Buick LeSabre with stock 140 amp alternator XS Power D3400 (under the hood) using pdb distro blocks Big 3 done with 2/0 ga welding cable Alpine CDE-HD149BT head unit CT Sounds Meso 6.5" components CT Sounds 60.4 CT Sounds 1400.1 Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs) Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders) Connection BT2 & BT4 550 (Audison) RCA's Bunch of Mojo Mat
