:banhim:hmmmmmmm
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
He probably meant no vs threads, which is what your thread was. It's one of the rules here because it usually turns into a heated debate and derails threads quite a bit. You can ask about other brands, but not which is louder than the other.
Because what is louder is a matter of opinion for the most part. What sounds awesome in some applications, might not be good for yours. There are way too many factors involved.
You can still get good recommendations without making it a vs thread. Quit antagonizing the moderator/admins, they are following the guidelines set in place. Getting banned isn't going to help you.
The best way to get what you are seeking is to give a budget, request subwoofers within that budget.
You made a vs thread Which it is clearly stated in the rules that they are not allowed.
