'80 VW Caddy (Rabbit truck) system, E30 dash, suspension...
Layered up with 10 layers of mat. Almost killed the 4th gallon of resin on this build.
I needed 2.39cu ft of internal airspace, I ended up with 2.55cu ft.
Thanks
Rings for the tweeters mounted
Stretched with grill cloth, resined, two layers of cloth, body worked, and mixture of filler/resin poured into the pod to make it more solid.
Coming along nicely.
Absolutely love this build...
01 Suburban Z71 - 5.3L - Black - 6" Lift on 35's - Pioneer H/U - Kicker Mids, 8" Polk sub.
Past rides-
07 Avalanche - Sunburst Orange - 4/6 Drop - Pioneer AVH-X5600 - 2/0 Royal Excelene - T/M fuse blocks - Stock and Singer 350 Alts - 4 Kinetik 1800 - Crecsendo BC5500 & S800.4 amps - 2 Tantric HDD 18's.- RE XXX 6.5 comps
01 Grand Vitara - V6 - 4x4 - Pioneer H/U - Incriminator 6.5 Comps - SSA XCON 18 - Skar 1500.1 & 84.4 amps - Singer 160 Alternator - Optima Yellow top..
I want to add cup holders but the E brake handle was in the way so out it went. I made a void in the sub enclosure by glassing over a 4" pvc and added an actuator.
I will be continuing the E30 theme into the door panels. I picked up some E30 window regulator motors and interior door grab handles/armrests. I took apart some new VW regulators and mated the E30 motors to them. The power windows are operating perfect.
I grafted the door handle mounting points to the door. I still have much more metal work to do to the doors.
Started on a trim panel/center console.
  • Who's Online   0 Members, 0 Anonymous, 1470 Guests (See full list)
