2011 Honda Accord Sedan(Slow Budget Build)
Ive never had a problem or voltage issues from crimping those type of ring terminals so to each their own. Now could soldering be the best method, sure and thats with any terminal. Just my .02
Lol. They are not crimp terminals the only thing you are doing is squeezing it around the wire, a proper crimp tool and terminals will form a cold weld.
I'd like to see you do that with those terminals and some vice grips or pliers.
Nowhere did i say they were crimp terminals and while i do agree i wouldnt use vice grips or pliers, i do mine different and have no issues.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
So how do you do yours then?
HAMMA CRIP!
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
I think I misunderstood you ...but I crimped them with these
Not the best idea but it works.
All joking aside pull it all out and use a real hydraulic crimp or solder or you will burn your car down...
Something like this below is a lot cheaper than a new car
http://www.amazon.com/Hydraulic-Battery-Terminal-Crimper-Crimping/dp/B00GXQ2E5E/ref=sr_1_1?ie=UTF8&qid=1420587880&sr=8-1&keywords=hydraulic+crimping+tool
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
So you still used the terminals improperly?
Na a friend had a 10 ton hydraulic crimp...used a 25 die.Afterwards i wrapped with electric tape..Still have to redo the ones in the trunk. I will be buying my own soon. Good to have
Did you use crimp terminals?
What everyone is trying to tell you is, it doesn't matter how hard you smash those style of terminals,or how much tape you wrap around them,they can fail! Wire will eventually work its way loose,and touch something it shouldn't! Then POOF! Its not worth all the time and effort your putting into your build, to lose everything over something so simple.
