1 ohm load to 2 ohm load with more power on same electrical
OK in general how much more watts could I run if I run more power at a higher ohm load with the same electrical due to the amp being more efficient.
For example if I am currently running 2k watts at 1 ohm without dropping below 13v with my electrical...what kind of power could I possibly run at 2 ohms.
Like could I get another 2k amp and strap them to 2ohms for 4k of power and run it ok (not dropping below 12v)
Or maybe just run a 2k amp at 2ohms to one voicecoil and the other amp to the other voicecoil at 2 ohms so each input sees 2ohms because the sub is dual 2ohms. To get a little less current draw more like 3000watts
So basically how much more watts can I run going from 1ohm to 2ohms with the same electrical without dropping below 12v. I know it is probably impossible to tell but I am hoping some has experienced this on here to just get an idea.
It depends on the amp, but usually it's not that big of a difference, around 10% difference if not less.
you won't see a big difference..now going from .5ohm to 2ohm, or 1ohm to 4ohm would be a big difference. most good amps have a 97% efficiency rating or more at 4ohms
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
if I'm not mistaken a 1500w amp at .5ohm draws almost the same current as a 3000w amp at 1ohm. even tho the watts are way different.
if that comparison helps at all
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Please don't post this misinformation.
If you can find 1 amp that can do this, i'll gladly pay it for you to use.
I agree with this. i ran my XXX 4K at 2 ohms then dropped it to .5 and holy hell was there a difference. i have went from 2 ohms to 1 ohm and there wasnt really a big difference.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
Crescendo S1500.1? They claim 97% efficiency at 2 ohms. http://store.crescendoaudio.com/symphony-s1500-1/
2008 Subaru WRX STI
K&N Typhoon Intake
Invidia Polished Stainless 3" turbo back with cat
Cobb Accessport
Dyno tune from Kaizen Tuning
320awhp 330ft-lb awtq
MTX 421D Sub amp
American Bass SQ900 Highs/Mids amp
Sundown Audio SD-2 10 D4
JL Audio XR653-CS 3-way Components
3sixty.2
Second Skin Damplifier Pro
Custom fiberglass wheel well enclosure
Transmission Line quasi-floor enclosure
http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/
Bill Fitzmaurice TLAH line-array hifi towers
9 Goldwood 4" mids (each)
12 Goldwood 1/2" tweeters (each)
NAD 1020 Preamp
MiniDSP 2x4 Balanced processor
Thorens TD166mkII Turntable
Hafler DH-200 Amplifier
http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/
https://www.facebook.com/HolyMountainGlass
I bet they have pet unicorns at their warehouse and the amps can generate rainbows too.
