AlbertGonzalez Posted January 10, 2015 Report Posted January 10, 2015 I want a small amplifier and i was thinking how hard would it be to convert a http://www.parts-express.com/6x100w-tda7498-class-d-amplifier-board--320-307 to use for car audio and using a processor or headunit to control the volume and a cap to keep my voltage up? I really want to find a way to make this work. Thanks in advance.
Triticum Agricolam Posted January 10, 2015 Report Posted January 10, 2015 You will notice on the specs for that amp the input voltage needs to be 14-39 volts. To get good power out of those amps you really need to be able to feed it at the upper end of that range. So the tricky part will be how do you feed it 35+ volts in your car? If you have a good way to do that it should work out fine. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
AlbertGonzalez Posted January 10, 2015 Author Report Posted January 10, 2015 I think the make converters but i don't know if its for car use i think it runs on 120v
Skullz Posted January 10, 2015 Report Posted January 10, 2015 Cost prohibitive once you get into buying a power supply with enough voltage to work. Arc Audio makes mini amplifiers. http://www.arcaudio.com/c/amplifiers_ks-mini http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR2.TRC1.A0.H0.Xarc+audio+ks+mini&_nkw=arc+audio+ks+mini&_sacat=0 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
islandpride684 Posted January 10, 2015 Report Posted January 10, 2015 The cost of buying the other parts to make it work costs just as much as an amp, I would buy the amp... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
AlbertGonzalez Posted January 11, 2015 Author Report Posted January 11, 2015 The cost of buying the other parts to make it work costs just as much as an amp, I would buy the amp... thats true.. Damn i like the small amp give though
Miguels Posted January 11, 2015 Report Posted January 11, 2015 fosgate pbr my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Popwarhomie Posted January 11, 2015 Report Posted January 11, 2015 PPI Ion 520.4 is TINY as well. I put one in a buddies car the other day. http://www.caraudioclassifieds.org/forum/testing-scientific-data-discussion/166480-my-test-precision-power-ion-i520-4-a.html 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
jk13 Posted January 11, 2015 Report Posted January 11, 2015 Plenty of small chassis options out there. Steve used the Soundigitals in a pumpkin build one year IIRC. Many more are coming out with some and usually list them under motorcycle or powersports on their web sites. Static drops are my bag.
Miguels Posted January 11, 2015 Report Posted January 11, 2015 i own a pbr from fosgate.. looking at the box it says its 6.78 x 4.25 and it 1.54 tall my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
