1500 watts on one 12" or 2 12"?
I have a Rockford Fosgate T1500.1, not the cp model. I will be buying sub(s) for it soon. I am still torn between getting a single 12" sub that can handle 1500wrms like a Fi Q or AA Mayhem OR getting a pair of 12" subs that handle less power like Rockford T1s or something.
For the info hogs, assume my electrical is all up to par and sufficient, assume a proper custom built ported box will be used no matter what sub(s) are selected. Also, I want my subs to have a good daily driver "sound quality" setup; note I do not want professional sound quality, just enough sq that I am happy. I have only had a pair of JL W0's (their lowest line of subs, yes lol) on 250wrms before, so I kinda want my new setup to be alot better. haha
Please note I am NOT trying to do a versus thread, I am simply trying to make sure I will be happy with this money pit I have already dug myself into. :)
2 12's should always be louder then 1 12 on the same power.
I'd choose 2 12's, and have a bit more power handling then necessary so you don't have to worry about anything.
Is space an issue? Can you fit the two twelves in a proper ported enclosure? Also I know you didn't ask, but if you can fit a single higher powered 15 you may be getting a happy medium. How easy to please are you? If you're only wanting a decent amount of bass then 2 12"s on 1500 W should do the trick. I had 2 12"s ported on a T1000BDCP and it was too much on some songs, not to mention got tired of the rearview being useless on any song with a halfway decent bassline.
1997 Lexus ES300
HU - Pioneer MVH 7350
Processor - Helix DSP
Front Stage - JBL P660C
Mid/high amp - Alpine PDX-F4
Subs - 1 IA Death Penalty 12
Sub Amp - Cactus Sounds PF300.1
2 is better than 1, i would rather have 1 good sub than two lesser subs. you could always add another good sub later when your ready. if you have 2 lesser subs when your ready for more power, you will need new subs.
But would it sound cleaner/tighter or just louder?
Space is not too much of an issue. I have enough room for 2 12s max. I could prolly fit a single 15, that is not too bad of an idea!
I would suggest either one 15" or two 12"s over a single 12" if you have the space. All else being equal more cone area is pretty much always better, for a multitude of reasons.
Builds:
If two subs have say 10 mm Xmax each but the 1 sub has 20mm at the same power handling than they should perform the same the only benefit if that was the case is two subs will cool more efficiently.
  • Who's Online   0 Members, 0 Anonymous, 734 Guests (See full list)
