Recommendations on front stage
05flareside
While your at it linear power blues is only comps you should run.,just sayn
I have NEVER recommended equipment that I run personally ... But if you think you can beat the products I run, White Lightning will be back in competition this year so I dare you to jump in my class ...
Op has a good budget.300.00 on amp. 200.00 on speakers .so let's buy 60 coax .I would spend 250.00 on 3 way PPI. Rest on amp plenty of decent 2 channels out there that price to power it..but I don't know shit.
But you never recommend equipment you don't run..
the op left his self wide open for suggestion by not giving us enough info to help him select what's best for his vehicle. With coax drivers, no work to the doors are needed externally. Also those truck are high enough that if he's not into stage and image, having external tweeters is not going to help him in any way. I'm only basing this off of the several Ford trucks I've worked on in the past, including one of my own.
Yes, if the application calls, I will run coax drivers. I have some in operation now, I just don't se a need to post everything I have.
sounds like a good idea to me.
Correct .... I mainly help out with application.
I've never had a cross word with this guy.
... And never have any problems with his suggestions.
Not sure she he's blasting me out of the blue like this ???
  • Who's Online   1 Member, 0 Anonymous, 1088 Guests (See full list)
