rockFord_Expedition's Rebuild (Old School RF, SMD/D'Amore, CE Auto Electric, DC Power, XS Power, SHCA) lots of pics inside
Looking beautiful man!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
A little more electrical which I should have posted earlier but I just found the pics. Theres pics I found that I dont remember taking and pics I thought I took but cant find. Go figure. Oh well, here ya go.
Had to 45 one of the Sky High lugs
This is where I grounded the battery and the alt case to the frame.
All 2/0 cable wrapped in tech flex and 3:1 adhesive lined heat shrink
The alt case ground. I guess I snapped this pic before I added the upgraded charge lead, so just the OEM one is in the shot but I assure you that it was upgraded and done the same way the ground was.
Probably wasn't necessary, but I took the OEM ground that ran from the battery to the body that you see here and added a 1/0 run on top of it just for good measure.
Charges nicely
Ok so I stumbled across a few more in progress pics, it would have been ideal to post these earlier but i guess it's better to post them a little out of order than not at all.
When you live in the desert you have to watch your step at night
12.6ish OEM Resting voltage. Sorry for the glare
More OEM
So after my upgrades I seen good gains in all areas. Resting voltage, cold and hot charging, and voltage under load.
Not too much volume in this enclosure and because of the subs and port, there wasn't much room for bracing, and between the 1" MDF, and not the cheap stuff, and all of the fiberglass the box is solid as a rock. I did add 1" wooden dowel above and below the port though. This system doesnt have too much init, but I know I have zero loss due to box flex.
On to some more pics...
Painted the visible part of the rear piece that can be seen through the port.
I put resin 45's along every seam of this thing but I'll be damned if I can find the pics.
And yes I cleaned up all of the loose glass fibers
This is looking MIGHTY fine!!! I'm tuned in sir!!
2011 Nissan Altima aka Red Ruby
HEADUNIT: Pioneer AVH X2700BS
ELECTRICAL:
-Singer 230a
-Northstar gr34
-(2) Northstar SMS220 w/ Custom Terminals from 12V Metalworkz
-100% Welding Cable
FRONT STAGE:
-(2 Sets) Hertz HSK165
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-(3) Sundown Audio SA REV2 12's
-Ampere Audio 3800.1 V2
MISC (NON AUDIO RELATED):
-Interior & Exterior Lights LED
-Gloss Black Roof (PAINTED)
-15% Front, 5% Rear Tint
-Roof Spoiler
-20" TSW Snettertons (20x8.5 front, 20x10 rear)
-Custom Projector Retrofit (FX-R 3.0, 6.5k HID, Morimoto Mini H1 (faux projector), Quad Starry Night Halos) ----- COMING SOON!!
-Aftermarket Fog Lights
-Custom Painted Engine Covers
My Build Log: http://www.stevemeadedesigns.com/board/topic/169869-woods-2011-altima-aka-red-ruby-new-video-more-updates/page-109
Retrofit Build Log: http://www.stevemeadedesigns.com/board/topic/185787-hid-projector-retrofitting-diy-by-wood/#entry2765346
