islandpride684 Posted February 1, 2015 Report Posted February 1, 2015 try this: Does the noise vary in amplitude when you adjust the volume control? If it does, the problem is probably power line related and not a ground loop. If this is the case, run the source units B+ (yellow) wire directly to the positive terminal of the battery. If this doesnt do the trick, you will probably have to use a power line filter on the source units B+ (Yel) and Ignition (Red) wires. Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Aj11 Posted February 1, 2015 Report Posted February 1, 2015 just throw a few thick strands of copper in between the rc inputs on the deck, and ground the chasi of the deck. I'll post a pic in a sec jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Aj11 Posted February 1, 2015 Report Posted February 1, 2015 it's really that easy. that's half the copper In 4g wire. push down in and push up to the metal bracket, then ground that metal bracket to a good ground. then put your rc cables on to secure the bare copper and enjoy! thats how i fixed my deck and several others. it's not pretty but It works! also works great for the RF 36 as well jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
thefourth Posted February 1, 2015 Report Posted February 1, 2015 try this: Does the noise vary in amplitude when you adjust the volume control? If it does, the problem is probably power line related and not a ground loop. If this is the case, run the source units B+ (yellow) wire directly to the positive terminal of the battery. If this doesnt do the trick, you will probably have to use a power line filter on the source units B+ (Yel) and Ignition (Red) wires. It was stated above it does not amplify when volume is increased Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
thefourth Posted February 1, 2015 Report Posted February 1, 2015 it's really that easy. that's half the copper In 4g wire. push down in and push up to the metal bracket, then ground that metal bracket to a good ground. then put your rc cables on to secure the bare copper and enjoy! thats how i fixed my deck and several others. it's not pretty but It works! also works great for the RF 36 as well In no way would I recommend doing it that way. Looks like an accident waiting to happen Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
islandpride684 Posted February 1, 2015 Report Posted February 1, 2015 try this: Does the noise vary in amplitude when you adjust the volume control? If it does, the problem is probably power line related and not a ground loop. If this is the case, run the source units B+ (yellow) wire directly to the positive terminal of the battery. If this doesnt do the trick, you will probably have to use a power line filter on the source units B+ (Yel) and Ignition (Red) wires. It was stated above it does not amplify when volume is increased You trying to correct everything, well since you are being technical, he said it goes away when the volume is at 0...technically it does vary in amplitude when the volume goes from 0 to 1... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
ImaNoob Posted February 1, 2015 Report Posted February 1, 2015 I get noise when my Ipod is plugged into power, Plays through all my speakers..If i unplug it from the power it goes away.. 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
Guest Posted February 1, 2015 Report Posted February 1, 2015 If you are going to ground the rca shielding to the head unit, do it this way. Much cleaner. Also, I wonder if the "noise" you talking about is the inherent "static" sound that is always present no matter what you do. However, this "static" is usually so low you can barely hear it at all.
SIDE SHOW Posted February 2, 2015 Report Posted February 2, 2015 if you turn the gain right down on the amp does it go away?
