4th order bandpass enclosure (fi Q 12")
lyons238
I'll disagree on the ratio thing hunter. I'll agree on the rest.
One of the most volent and balanced 4th ever in my life was robin butlers Tahoe. Have other ones been louder? Sure.
But when you can murder 15hz to upper 60hz with a very similar intensity? I don't know it seemed like he didn't have a peak to the ear. I'd want mind to perform like that even if I lost a few Db peak. I hate that my bandwidth is 26-38 with authority. Really 30-34 lol.... But your band pass seems pretty successful also with both bandwidth and output so I'm sure plenty of your points are valid vs my noobish observations.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
2.4:1 over here.
17-60 flat. But I digress.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Don't worry about ratios.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
+1
Just because a 1:2 or 1:4 or whatever ratio was right for someone else's setup doesn't mean it will be right for yours.
Hey Raptorman, what where the box specs on your setup? I know it worked out really well and it might give lyons something good to compare against when he plays around in WinISD.
Builds:
24 ported, 10 sealed, 341 sq in of port
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
All these sexy 4th order subs and me with no 4th order friendly subs!
I guess I'll just have to buy another ride and 4th order that one!
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
I'd go between 1.5 : 1 and 2.5 : 1. Id lean more to 1.5-1.75 to 1 ratio. Build 1 side to the sealed Reccomended. Then take that to find the 1.75 part of the ratio. Tune between 44and 48hz. That should still dig down to 25hz. Most people tuning to 42 reach down to 20 and that's much much lower.
Most people with 4ths say to give 16-22 sq inches of port per cube with a slot. (Normal ported being 12-14 sq inches) so if I guess with aero ports (normal ported being 8-12 sq inches of port per cube) so my guess would be to shoot for 14-16sq inches of port per cube with an aero.
Definitely invert the sub.
Power handling depends on the ratio you choose, closer to 1:1 you will lose power handling, lose SPL and gain bandwidth. Closer to 3:1 you will gain power handling (mechanically), spl, and lose bandwidth.
The high qts option and stuff I don't think is needed, I'm sure it could help. I've heard that higher qts subs can handle playing lower below tuning.
If you have an android phone then download the ultimate car audio App from xplicit.
Those are all the questions I could answer off the top of my head. Hope it helps.
Anything below 2:1 is a waste imo. Tuning point is the resonant frequency of your sealed chamber, not just a guess.
Port area is strictly based on your cone area/volumetric displacement, not tied into your ported chamber volume whatsoever.
Yes invert the sub.
Power handling is based on sealed volume/port area. Bandwidth will hardly diminish whatsoever from higher ratios, to a certain extent. 3.5:1 is the most I'd do for musical.
High qts option is Fi's way of saying "Sealed box friendly", which, also means 4th order friendly. So get high qts if you can.
I already have the non qts version, will this still be okay? Also I have a 2000w amp so I figure the sun will see around 1700w, would it be wise to go 1.5 in the sealed portion which is as big as the Q is supposed to see or would something like a 1.25 or 1.3 be better for that amount if power?
  • Who's Online   0 Members, 0 Anonymous, 386 Guests (See full list)
