rockford technology
emperorjj1
i believe bdsync is when you use a power off one amp and a negative off the other. and slave/master is when you connect them (via cable) to run different amps to different subs, but need all the settings the same.
bdsync is for strapping 2 amps together to make one large amp.
master/slave is to make sure that when running multiple bass amps, whether strapped or not, they all have the same signal in and gains/bassknobs/frequency settings all matched  automaticly.
Follow my Tweet (Twitter)
go to RF.com and check out their owners manual for the amp you're trying to use.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
