Is it crucial to comepletely seal a ported box?
Totalnoob
If there is an air leak around the subwoofer surround....right where you put the screw. Would that be effecting the performance of my sub a lot if the box is ported?
All the edges of the box are fine its just around the sub that has a leak.
Dap seal n peel caulking can fix that real quick and it will be removable.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
yes
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Totally seal it, any leak will hurt output
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
You'll be hearing different resonant frequencies as the leak(s) have a tuned frequency. You will also hear the compression of the air as it moves through the leak(s) making a chuff chuff chuff sound.
Spend the extra 3 minutes sealing the box's edges. I also suggest getting a soft foam ring or something along the type to cut out and make a ring for the speaker to rest on to help seal the baffle some more.
Yup, ^ What they said.
Now did you cut the original hole? Or is it a pre-fab?
If you did, you probably cut along the outside of the line you draw. I made the same mistake a few times til I figured it out.
1. One trick that worked for me is to take a scrap piece of wood and drill the radius of the subwoofer mounting diameter.
2. If it's 11", than drill 2 small pilot holes 5.5" apart.
3. place a screw in each hole. than back them out almost all the way out, leaving only the tip on the under side of the scrap wood..
4. decide on the center of the surface you are about to drill, than cut
5. Drill a pilot hole in the center.
5.Drill one of the screws in to the pilot hole.
6.Now slowly and evenly spin the scrap wood into circles, allowing the other screw to scratch the wood. You can even press on the outside
screw to really dig into the wood. The wood has to be flat, if it's angled, the circle will be too big. turn it flat!
7.Back out the center screw.
8. Now measure the circle you just made. It should be exactly 11".
9. Drill a hole big enough for the jigsaw blade to fit into to start cutting the circle. CUT ON THE INSIDE, NOT THE OUTSIDE.
This is something my father's best friend taught me as a teen. He was a jack of all trades, knew alot about everything.
He built the addition to his house and the cabinets in it! Guy was phenomenal!
It works better than a compass since the pencil may move messing upthe circle, or the arm may swing wide and also mess up your circle.
If you used a router, than you definitely made the hole too big! lol.
Not trying to sound like a know it all, because I don't but reading this thread, I've been there!
-Frank
  • Who's Online   1 Member, 0 Anonymous, 1311 Guests (See full list)
