audiophile headunits???? where did they all go???
Nsomnia
They went the same place as audiophile source files. Head unit manufacturers are only caitering to the market's demands.
I like my 80PRS. Would I call it "audiophile"? Maybe, depending on the source file used.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
i know its been done before in analog before all the fancy DSP, i guess i was using misleading words. but im saying in this modern day, why wouldnt you use a DSP, its easier, probably cheaper, less space, less time, easy to tune. much easier and can change on the fly
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
it is not cheaper
it takes up more space
it is not easy to tune (correctly)
yes you can change it on fly in some cases some DSP require a laptop i don't call that on the fly or simple tunning
and what if i told you ananlog done right will almost ALLWAYS sound better then a DSP?
are instruments digital or analog? what is SQ? the reproduction of LIVE ANALOG music just saying
DSP just made people lazy but i cant say to much on that every single car i have has a DSP in it im up to 3
i will admit i am lacking the skills to do an SQ analog build i need the crutch of a DSP
For the average user the 80PRS is a great unit the signal output on the unit is not that great if you have a DSP or are serious about SQ the 80PRS is never used
the only place an 80PRS is used in SQ comps is in stock class where you can not use a DSP so its kind of a cheater deck for stock class
any other class you will not see the deck used
thats far from "audiophile"
There are so many conflicting opinions on DSPs throughout the audio society.
For example you can take THX certified theaters (to my current knowledge on their requirements). For your certification you must use a Linkwitz-Riley crossover with a -24dB/octave slope at the crossover points. However one of the men who helped create it (Linktwitz) recommends use of active crossovers instead of analog. Stating:
"While the active-network approach may be costly and only applicable to top performance loudspeaker systems, it can result in a system with improved dispersion characteristics and this a very firm stereo image.
On appropriate program material it will not only give a smooth lateral spread of the image but also a noticeable enhancement of depth perspective."
This was also a work done as long ago as 1976. The time between then and now with the advancement of digital electronics "may" have greatly increased reproduction and the uses of active crossovers.
His work can be found here, testing both analog and digital and a section on burst testing.
http://www.linkwitzlab.com/JAES/jaes_papers76.htm
Krakin's Home Dipole Project
i have had the awesome chance to hear a great fully analog system there is definitely a difference i preferred the analog over pretty much any DSP i have heard since this could just be personal preference. there are the ones that only like the sound of digitized music and so the conflict will allways be there
it just makes sence to me that analog music would be reproduced better by an analog system
just like the big tweeter debate silk vs aluminum
Aluminum being metal works better being 99% of the sound tweeters reproduce is from a metal instrument
VS.
Silk is softer and still reproduces good metal sound
im still out on this one i use to hate metal tweeters before i knew how to tune them now i really like them better then silk? im still on the fence
  • Who's Online   0 Members, 0 Anonymous, 878 Guests (See full list)
