Mobile Sound Works Custom Made Boxes
kyangs
Has anyone ever heard of the brand and used the brand? Is 3 cu. ft good enough for that sub. Share your thoughts and insights.
http://www.mobilesoundworks.com/product_p/3_0-msw-112-round-box.htm
Setup:
American Bass XFL 1222 @ 1500w RMS
-Rockford Fosgate T1500-1BDCP
Mobile Sound Works Custom Made Box:
  • Single 12" custom slot-ported enclosure
  • Compatible with most 12" round woofers
  • 3.0 ft^3 slot-port tuned @ 35Hz
  • Solid MDF construction
  • 1-1/4" Reinforced MDF front baffle
  • Durable dark gray carpet
  • Gold-plated binding post terminals
  • Box volume (net. int.): 3.0 cubic feet
  • Tuned to: 35Hz
  • Woofer cutout diameter: 11" round (oversized subs may require slight mod)
  • Box weight: 58.5 lbs.
  • Dimensions (W x H x D): 37-1/4" x 17" x 14
Looking at the specs and pictures I'm guessing its built out of 5/8" MDF instead of 3/4", its doesn't appear to have any internal bracing, and I bet it doesn't have as much port area as it should.
So basically its like every other prefab, and should probably be avoided.
One a side note, I think its funny they call it a "custom" box, what's "custom" about it? Nothing.
Builds:
single 12'' custom slot ported enclosure...
compatible with most 12'' round woofers...
^^ made to fit "most" 12'' woofers... NOT CUSTOM
Custom - (noun, adjective) made or done to order for a particular customer
save your money
2004 Jeep Liberty Limited
2 13w7s
skar 3500
cnf mids (soon)
xs batteries
It's custom as it's the only prefab using a double layer 5/8" baffle.
Lol, yup, my bad. It should have been obvious!
Builds:
Thanks for the replys. I guess you guys will have to wait till my unboxing. I sure hope its not as you say. Here is what I found on Youtube.
Link:
It seems like its built pretty sturdy. Let me know your thoughts on the video.
Ordered before you even asked, typical.
Not impressed.
Builds:
not impressed.
wouldnt buy.
this is custom and built to the woofers specs, vehicle limitations, power, etc... not that crap that (fits most 12inch woofers)...
1.25 inch baffles? thats cute this port is thicker than your baffle...
10553602_806323596068624_504803037907157
10460781_807192322648418_123831957203654
10592818_807192359315081_767840960076681
46702_728094560558195_1552423215_n.jpg?o
10003910_728152433885741_1538024448_n.jp
1970439_726107824090202_927809854_n.jpg?
10401397_768669959833988_752051406389368
10357461_770619412972376_237895395740008
10304631_785000871534230_566996569831503
10468081_785254031508914_172642069270814
ahh a 3 inch baffle almost 3 times the baffle as the custom box that fits most round 12 inch subs...
10502142_795130940521223_551508584776005
10553520_795131203854530_380856775866261
10934087_900647689969547_456164003206809
10953210_900647703302879_729317758286056
10420130_905611572806492_870198535373010
This must be the box in question...
Their carpet job is hideous. you can see every seam clear as day.
Looks like they dont know how to carpet so they carpet a end panel and then staple it to the box afterwards which adds no strength to the box and a possibility to vibrate loose down the road.
Ill take one of the boxes I built that I posted above any day. Hell Id take one of the boxes built by my old friend that also does boxes any day before these guys! LOL
You can see the seam on the top partly in this photo, not even centered in the box either.
But the nails or staples they used through the carpet to secure what looks like the side panel is way to noticeable.
3_0-MSW-112-ROUND-Box-6.jpg?1325001854
You can see the seam better in this one on the top of the box.
3_0-MSW-112-ROUND-Box-5.jpg?1325001854
3_0-MSW-112-ROUND-Box-2.jpg?1325001854
  • Who's Online   0 Members, 0 Anonymous, 4888 Guests (See full list)
