it still pounds dec , when i play cd-- im getting a head unit installed in a month or 2
Christopher
My vehicle
http://www.stevemeadedesigns.com/board/garage/vehicle/3100-buick-rainier/?tab=images
2005 Buick Rainier CXL - Bose Premium & OnStar
Subs - P1 x 2 Ported Box
Amp - Kentwood Excelon X500-1 Mono block D amp - 1000W rms 1- Ohm 500W rms 2 ohm
Deck Kentwood BD362U
Mids / Highs - Bose Premium Sound System
YouTube Video of system
Yeah, and a 500W amp on OEM electrical may not even ever make 500W
Most stock electrical can handle 500 watts no problem.
Yes it can but I mean bone stock as in most shops don't do big 3, and all of that. Not saying it's an overload on the electrical.
Nobody that actually knows anything will be able to tell you where to set your gains or anything else at over the internet, but we can help you get to where you need to be.
The installer of this gear, did they use an oscilloscope or a DD-1 to set your gains?
Also, does that amp have high level inputs or did they use a line out converter to send signal to the amp? LOC's are trash.
What you need to know is the maximum undistorted volume of the head unit, then the gain needs to be matched to that. Bass boost is usually a bad idea unless you only like a narrow band of bass to play well and to hell with the rest.
Where are you located at?
take the max number the headunit's volume goes up to and multiply by .75 This gives you the volume setting to use when setting gains
2010 Ram 1500, Pioneer deh80prs,2-12" RE SXXv2's downfired in vinal wrapped center console box, kenwood 6x9's in the doors on a mtx 4 channel, viper 5901, big 3, kinetik 2000
No it doesn't. That is terrible advice and has no basis at all
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
That sir, is quote worthy.
Stock Bose sound
If the car has a stock amp and you put a hi low converter after the amp your going to have problems
the only issue you would have is if you put the loc on the mids and highs that dont produce the sub-80 hert signals
Damn so even though my DD-1 says my HU is clean all the way to 40/40 I should only go to 30 since that's what you say to do?
Stock Bose sound
Another incorrect statement
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
