can't find the answer!
not to carry on a thread...but, in theory, one should have as many runs of positive as ground...and really, there is no such thing as overkill when it comes to grounding? just lurkin for knowledge.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Going front to back? No not necessarily. My car is unibody and I saw no gain when I added a negative run of 0ga. Switch that run over to positive and I gained .3v.
Best way is to experiment with a clamp meter
FWIW I've found a great spot to ground to is the strut tower bolts. Both front and rear.
thanks Snow...I'll have to try and make it up to your neck of the woods one day to sheck out your set up!
Singer 220 amp alt
I see what your saying so clearly by laws of physics I should I will run 2 positive and 2 negatives. Thank you.
Then you don't see what I am saying.
You don't need front to back ground runs 99% of the time. Period. Ground to f/r strut tower on same side of vehicle and as many + runs as you are able within reason.
Singer 220 amp alt
SHIT DOUBLE POST...MY BAD
Singer 220 amp alt
  • Who's Online   0 Members, 0 Anonymous, 2926 Guests (See full list)
