Times RUNNING OUT to get the votes in for ol Bis-Kwik for SOTM! If you like this build be sure to cast a vote for it! Also make sure to check out all my side stories to this build!
It's on it's way back home!!!!!!!!!! Can't wait!
Done some quick work to the speaker adapter today as well as to my Bass knob! I put a bigger LED on the Bass knob cause I did machine this into the Drive-In speaker to show once the amp is on. I also had to add my quick connection to the 8 LED's that are on my speaker adapter BUT once I hooked it all up the LED'd on the speaker adapter are dim so I'll go to Radio Shack tomorrow and pick up the stuff to build a small circuit board with a relay to control them. So this is where I'm at today!
Bigger LED! How do you like how I had to bend the leads on it! CUSTOM!
The speaker adapter with all the LED's in it and the quick connect wired up
All soldered & heat shrink on it
Hooked up & ready to test! LED's on the speaker ring was just too dim I'll take care of that tomorrow! HEY some times things don't work out the first time and you have to re-do things! That's that CUSTOM LIFE!!!!!
WOW I didn't expect this but there is a 24 hour FLASH vote off between me and RF's system for the SOTM! If you like my current build then cast a vote for it!
http://www.stevemead...our-flash-vote/
Be sure to cast your Vote for my build if you like it on the 24 Hour Flash Vote for SOTM! Also be sure to read all the side stories to this build in the links below! Theirs more to it then meets the eye!
Drive In Theater Speaker Build
Suitcase Build
Coleman Cooler Build
X10 Box Build
Complete Build Log On Bis-Kwik
NEW SUB'S 8 SundownAudio X6.5sw Build
Getting that wiring game on!!! She's tight, that's a BUNCH of stuff in that Drive-In Speaker!!
Wiring about done! I got to label every thing & put my quick connects on it! I did run 2 spares just for growth later on! Never know when you want to add something else & need some extra wires!
OH yeah in the Wagon now! Can't wait to see it at night!
OOOOOOH WEEEEEE Got that blue going on!
10441405_913026455384147_465010682250790
11047956_913026525384140_318848584223391
11059394_913026605384132_626301764378265
11127819_913026625384130_724536779046994
What looks better with the Switch extension on or off?????
OFF
ON
