kiko Posted April 1, 2015 Report Posted April 1, 2015 Hello fellow bassheads, I need help finding out what is my problem with my amp and subwoofer system. i have the system hooked up for approximately 1 yr and 1/2 now and it recently gave me some problems. A few days ago i notice that i wasnt thumping anymore so i checked up on it and it was not playing. So i first check the hardware (Hifonic brutus 1100watt & 2 sundown e8v2). All hardware work and then i refer to the troubleshooting process on the manufactures manual and did the remote power test (used a wire to link the 12v power to the remote wire) and it worked. So i figured i had some loose ends on the remote wire side. My remote wire is wired to the cigarette lighter 12v plug. So i proceed to checking the fuse and it was not burnt (changed it to a brand new fuse anyways). Still didnt work, Then i did a straight linked from the cig lighter to the remote terminal. and it still doesnt work. So now im clueless of why it doesnt work!?!? (keep in mind the linking the power terminal to the remote terminal works) If anyone has any ideas of whats the problem let me know.. PLEASE!! Thanks in advance
SIDE SHOW Posted April 1, 2015 Report Posted April 1, 2015 Remote on the amp isn't getting a signal or a strong enough signal for it to turn on.
Kyblack76 Posted April 1, 2015 Report Posted April 1, 2015 Put meter on remote... (im sure you will find it dead) Its seems as though, that wire has a "air gap" in it some where... Run new remote from turn on hot..... Enjoy music. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SIDE SHOW Posted April 1, 2015 Report Posted April 1, 2015 what headunit is it? how did you have it wired befor? what fuse did you replace. pics of amp setup and wiring?
rockFord_Expedition Posted April 1, 2015 Report Posted April 1, 2015 Run a new remote wire, preferably to the deck. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Do-LowHrzHurts Posted April 1, 2015 Report Posted April 1, 2015 I would do a resistance test on the remote wire to see if it may have a break or got roasted some how from getting pinched. Re-run remote wire if needed. Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
rockFord_Expedition Posted April 1, 2015 Report Posted April 1, 2015 It;s either the power source for the remote wire or the wire itself. OP could trace the problem if he wanted to, but in the end he will still need to remedy the situation. Or, he could just remedy it to begin with. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
kiko Posted April 1, 2015 Author Report Posted April 1, 2015 Tested the power source.(the cigarette plug) (how i know its working is the fuse blew). At first i figured it might have been pinched or messed up so i re-ran another wire to the remote terminal to test it and I still got nothing. But the Blue LED accenting is on indicating it works but its a very dimmed blue (like no juice).. I will try and re-splice and rerun the whole remote wire as soon as i get the chance tommorrow. Hope it works! THANKS FOR YOUR INPUTS GUYS!!
kiko Posted April 1, 2015 Author Report Posted April 1, 2015 what headunit is it? how did you have it wired befor? what fuse did you replace. pics of amp setup and wiring? Stock, Same as 1 & 1/2 years ago, the cigarette lighter fuse, Cant provide pics, but it was a basic sub installation(hi/lo con is to the rear speaker, Knuconcept wiring kit 4awg)
