rockFord_Expedition Posted April 2, 2015 Report Posted April 2, 2015 What year make and model is your vehicle? 2012 toyota camry se http://www.modifiedlife.com/2012-toyota-camry-car-stereo-wiring-chart/ Gray wire on OEM harness Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Broke_Audio_Addict Posted April 2, 2015 Report Posted April 2, 2015 if the cig lighter works.. and you can "charge your ish" with it.. That means its AFTER that. Find and run a KEY'd on from your fuse panel. If your using OEM source. This is basic. You just need a "key'd" on. Get away from the cig ligher as a turn on anyway. i dont want to run off my fuse panel b/c i dont know how i can do it and still keep the fuse cover on it. I have a 2012 camry se and the only thing that turns on with the car (interior-ly) is the cig lighter location unless there is somewhere else i can tap to? Help Me Locate (PLEASE!) Thanks in advance http://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2 Usually the radio fuse is 12v switched. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Kyblack76 Posted April 2, 2015 Report Posted April 2, 2015 if the cig lighter works.. and you can "charge your ish" with it.. That means its AFTER that. Find and run a KEY'd on from your fuse panel. If your using OEM source. This is basic. You just need a "key'd" on. Get away from the cig ligher as a turn on anyway. i dont want to run off my fuse panel b/c i dont know how i can do it and still keep the fuse cover on it. I have a 2012 camry se and the only thing that turns on with the car (interior-ly) is the cig lighter location unless there is somewhere else i can tap to? Help Me Locate (PLEASE!) Thanks in advance http://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2 Usually the radio fuse is 12v switched. or a few other dozen things. Meter a turn on.... done. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
kiko Posted April 8, 2015 Author Report Posted April 8, 2015 Hello guys, I have recently solved my issue with the low power issue. It was due to a faulty Power wire fuse. I would like to thank you guys for your inputs in my temporary problem.
