Rich Schenk Posted April 7, 2015 Report Posted April 7, 2015 Can u run more then one alt? I would think that would help your issue. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
khinds94 Posted April 7, 2015 Report Posted April 7, 2015 I think it's a batt problem. You would have to draw a LOT of current to get them into 13s from 18v With all that reserve and a 340. Just me though 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
firebirdude Posted April 7, 2015 Report Posted April 7, 2015 You're quadrupling the current draw. What did you expect?
khinds94 Posted April 7, 2015 Report Posted April 7, 2015 You're quadrupling the current draw. What did you expect? Lol not really. And 2 3800s are going to get him like like 7-8k after curve and theyre are plenty of people on this forum powering 8k with a 340 and 6 batts on reserve. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
Kyblack76 Posted April 7, 2015 Report Posted April 7, 2015 I know my two ampere 3800's at .35 take my singer dual hair pins down to 12.9 after 3-4 demos. Im charging at 14v with a medium to low bank reserve. Those boards pull current and make power. Mine do anyway. I also know those 16v bats have had some return issues. Ive seen a lot go back for replacment.... Id check each one, on its own...... Charge it up, and check it frequently to see where it rests.... you may have one (or more) that are not holding a charge what so ever. Thats a pretty decent bank to be seeing 13v when your running that high. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted April 7, 2015 Report Posted April 7, 2015 I would also clamp your alt..... make sure your making around 275-300 when you play music/burp. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted April 7, 2015 Report Posted April 7, 2015 Sorry to keep at this. Also, The reason when you see people run HIGH volt, normally have 150% of reserve. Or multiple alts, or both... The reason being is the amp hours on a 14 or 16 volt bat compared to a 12v bat, is retarted. The amp hours on a 12v bat is usually double or tripple of a high volt bat. I dont know the specs on that bat, but i bet the reserve on it is weak. VERY weak. When you see people running high volt, and they demo, they have 2 dozen bats..... not half a dozen. Again, i dont know, but, im willing to bet 2 of my bats, have more amp hours than your entire bank. Ill bet your burp scores will be great, but, long runs, may fall flat.......... You take the alt down, and your reserve will falter fast. If you dont have enough. Hell, you may hold better voltage, running 12v, and a reserve like mine. I dunno. TIme for you to do some trouble shooting..... good luck, post what you find. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
RooTxBeeR Posted April 7, 2015 Report Posted April 7, 2015 You're quadrupling the current draw. What did you expect? Lol not really. And 2 3800s are going to get him like like 7-8k after curve and theyre are plenty of people on this forum powering 8k with a 340 and 6 batts on reserve. What Kylar said Sorry to keep at this. Also, The reason when you see people run HIGH volt, normally have 150% of reserve. The reason being is the amp hours on a 14 or 16 volt bat compared to a 12v bat, is retarted. The amp hours on a 12v bat is usually double or tripple of a high volt bat. I dont know the specs on that bat, but i bet the reserve on it is weak. VERY weak. When you see people running high volt, and they demo, they have 2 dozen bats..... not half a dozen. Ill bet your burp scores will be great, but, long runs, may fall flat.......... You take the alt down, and your reserve will falter fast. If you dont have enough. Hell, you may hold better voltage, running 12v, and a reserve like mine. I dunno. TIme for you to do some trouble shooting..... good luck, post what you find. This x2. OP, you increased your resistance a shit ton, and on top of that, are running a 18V system. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Miguels Posted April 7, 2015 Report Posted April 7, 2015 You're quadrupling the current draw. What did you expect? Lol not really. And 2 3800s are going to get him like like 7-8k after curve and theyre are plenty of people on this forum powering 8k with a 340 and 6 batts on reserve. You do know that 12v batteries have more reserve than 16v batteries right? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted April 7, 2015 Report Posted April 7, 2015 Look at every build with 16v batteries.. They have 24+ batteries my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
