power wire size
I will be running 2 Rockford Fosgate bdcp 1500s and a mosconi as200.4. Alternator will be a Mechman 370 amp, both bdcps will be ran at 2 ohms. What i would like to know is, will one run of 0 gauge wire be enough to support the current. This set up will be for a daily driver playing music only. your help is greatly appreciated thanks.
1 1500bdcp averages 100A on music @ 13.8V so 200A for both, lets say the Mosconi does the same, so that is 300A right there, your wire is rated at 350A max, like Skullz said you'll be pushing it...I would do two runs and be on the safe side...just my suggestion...
Do you know what brand and type of wire you'll be running?
Batteries are xspower d3400 under the hood and d3100 in the rear. The way i will be running the amplifiers, max current draw will be around 250 amps. I will be using knucoceptz wire which claims to carry a max of 375 amps of current draw with 20 ft of cable, but it will probably be around 17 ft that i run.
One run will be fine.
Extra never hurts though.
Thanks i really appreciate the help. I was looking at sky high sight and i seen some 2/0 gauge can any one tell me max amps on this cable.
  • Who's Online   0 Members, 0 Anonymous, 2926 Guests (See full list)
