power wire size
Thanks i really appreciate the help. I was looking at sky high sight and i seen some 2/0 gauge can any one tell me max amps on this cable.
I believe sky-high rates it 500 amps for 20 ft.
Ofc.
Which is the only wire I'd consider using.
With grounding the rear battery is it ok to ground it in the rear, or should it be ran from the front to the back. With other installs i have always grounded in the rear, but i keep reading and most people run a ground from front bat to rear bat.
Either way is fine.
For you size system a 2/0 is fine in ofc
You will see voltage differance between 2/0 for ground or chassis but how much of if, or if noticeable in rms will depend on so many things,
Idd big 3 in 1/0 (easier to bend and fit in to look nice)
I also like to grind mine like this
  • Who's Online   0 Members, 0 Anonymous, 2926 Guests (See full list)
