JakeHarling Posted April 13, 2015 Report Posted April 13, 2015 I have a Double cab Tacoma with this room, 48 inches wide, can go up from the floor to the roof 36 inches, and from behind my seat to the cab 24 inches. The subs are 2 Massive Audio GTX154s They are DVC 4 ohm 700rms. I want a box that will hit lows really good, so im guessing 30-35 hertz? Can someone design a box for me? I can build it Ive built boxes before just not good with designing. Heres the specs from Massive per sub. Size : 15 Watts: 1400 RMS: 700 Cone: UV Treated/Non pressed paper Voice Coil: 2.5" Dual 4 Ohm Surround: EROM Foam Magnet: 120oz Terminals: 5 ay binding push terminals Basket: Heavy Gauge Steel Tinsel Leads: Woven Road X-Max: 15mm + 10mm top plate SPL: 88.1 dB FS: 34.6Hz Ported box 20"H x 15"D x 24"W / 14.05 sq. in. Port Area
DrewJones Posted April 13, 2015 Report Posted April 13, 2015 PM'd TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐
audiofanaticz Posted April 13, 2015 Report Posted April 13, 2015 OK... I told you do not sell your designs here, PMing other members to do so is not going to happen, they just got disabled. Jake, there are people that will help you for free here, just give it a little time. Don't go and pay a guy that is trying to sneak around and message you against the forum rules that wants to charge you for a design.
JakeHarling Posted April 13, 2015 Author Report Posted April 13, 2015 Joe X if you see this I'd like your help if you don't mind.
JakeHarling Posted April 13, 2015 Author Report Posted April 13, 2015 Its a pioneer gm-d9601 they say its underrated but it says it does 1200 at 1 ohm
Joe X Posted April 14, 2015 Report Posted April 14, 2015 Here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, figure is just an assembly guide, bracing is 1 1/4" wooden dowel rods:
