Joe X Posted April 17, 2015 Report Posted April 17, 2015 If they got louder out of being broken in already then I don't think that's the issue. Some stiff subs arguably can get hotter before break in.
Joe X Posted April 17, 2015 Report Posted April 17, 2015 word of advice. ditch the sealed box and build a ported box.. chances are the sealed box is not allowing the sub to cool itself. that and turn your gain down not up Sub's are in the trunk ac won't get there and how much down it's only between 3 and 5 now can't do a sealed box trunks not big enough kinda awkward the way my trunk is You can reverse mount the subs and use your subsonic filter to reduce some power from going to the subs (not for cone control as with ported), what's odd is that you say they got louder suddenly, check voltage at the amp input terminals, subs impedance and reset your gains, you will need a digital multimeter which you can find even at walmart. Ok question could they have not been broking in yet? Lol bought them from a buddy a few months ago If they got louder out of being broken in already then I don't think that's the issue. Some stiff subs arguably can get hotter before break in.
gckless Posted April 17, 2015 Report Posted April 17, 2015 I know my sub was getting warm because the ported box I had was too small. Switched to a good size sealed box and no more issue. The box being sealed is not an issue. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
GS300Cali93 Posted April 17, 2015 Author Report Posted April 17, 2015 word of advice. ditch the sealed box and build a ported box.. chances are the sealed box is not allowing the sub to cool itself. that and turn your gain down not up Sub's are in the trunk ac won't get there and how much down it's only between 3 and 5 now can't do a sealed box trunks not big enough kinda awkward the way my trunk is You can reverse mount the subs and use your subsonic filter to reduce some power from going to the subs (not for cone control as with ported), what's odd is that you say they got louder suddenly, check voltage at the amp input terminals, subs impedance and reset your gains, you will need a digital multimeter which you can find even at walmart. Ok question could they have not been broking in yet? Lol bought them from a buddy a few months ago what would "breaking in" have to do with anything..... Its odd that it seems to b hitting harder now and idk how to say it but miguels said to turn the gain down it was between 3and 5 no its at least at it seems to have lowered the bass
C'sgetdegrees Posted April 17, 2015 Report Posted April 17, 2015 Did you tune your amp with a dd-1? Are they hot every song? Electrical, clipping, box, can be a number of things 05 Escape 2 Ascendant Audiio Mayhem 15s dual 1 Populus Audio 6500 (the only one around ) 1/0 SHCA OFC XS 3400 under the Hood XS 3100s in the rear X2 Pioneer 80 Prs Pac Prv mids and highs 2 8s per door 1 tweet
GS300Cali93 Posted April 17, 2015 Author Report Posted April 17, 2015 Did you tune your amp with a dd-1? Are they hot every song? Electrical, clipping, box, can be a number of things No havnt gotten one yet moneys a bit tight I havnt tested them to see if there hot every song did I need to turn my gain down? Feels like I lost some bass
Triticum Agricolam Posted April 17, 2015 Report Posted April 17, 2015 I know my sub was getting warm because the ported box I had was too small. Switched to a good size sealed box and no more issue. The box being sealed is not an issue. +1 Sealed boxes should have greater thermal capacity than a ported box due to impedance generally being higher. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jeff4661 Posted April 17, 2015 Report Posted April 17, 2015 Turn the gain up..... I smell a troll lol Current build 05 Yukon SLT http://www.stevemeadedesigns.com/board/topic/195350-jeffs-05-yukong-wall-build/
Miguels Posted April 17, 2015 Report Posted April 17, 2015 I know my sub was getting warm because the ported box I had was too small. Switched to a good size sealed box and no more issue. The box being sealed is not an issue. +1Sealed boxes should have greater thermal capacity than a ported box due to impedance generally being higher. Right.. Hopefully you're willing to pay for his subs when they overheat and burns the coil due to him not being able to smell the coils sizzling.. I think he is sending a clipped signal my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted April 17, 2015 Report Posted April 17, 2015 word of advice. ditch the sealed box and build a ported box.. chances are the sealed box is not allowing the sub to cool itself. that and turn your gain down not upSub's are in the trunk ac won't get there and how much down it's only between 3 and 5 now can't do a sealed box trunks not big enough kinda awkward the way my trunk is You can reverse mount the subs and use your subsonic filter to reduce some power from going to the subs (not for cone control as with ported), what's odd is that you say they got louder suddenly, check voltage at the amp input terminals, subs impedance and reset your gains, you will need a digital multimeter which you can find even at walmart. Ok question could they have not been broking in yet? Lol bought them from a buddy a few months ago what would "breaking in" have to do with anything..... Its odd that it seems to b hitting harder now and idk how to say it but miguels said to turn the gain down it was between 3and 5 no its at least at it seems to have lowered the bass That's how it works.. Turn gain down it gets quieter. Turn the gain up gets louder but run the risk of clipping and damaging equipment. If you don't have the proper tools turn the gain way down. Yeah I know it sucks when it don't get loud. You will also be disappointed when you tune the amp and is not as loud with a clipped signal my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
