CZ702 Headunit Issues (static)
Just tested the HU with the DD1 and its distorting at 32. Is that normal? I know a lot of you say it's clean throughout.
fucking wait...... (like your alt)
tested your head unit at what over lap.... did you do it right?
a "station" that was all static ? .. how does the USB play ?
Yeah I know right, I have shitty luck. I followed the manual for the DD1. Set all EQ's to 0, plugged an rca into the top of the DD1, played track 1&2 (both distorted at 32). I thought about the station thing and switched it over to BT and had the same issue. Like I said may be me shitty luck.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
It sounds like to me the speaker wire leads are touching the HU or each other
he said he turned the internal amp off. probably not something to do with speaker leads.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
no touching here haha
4B26E329-E39E-4951-A203-1DC90BCF41D6_zps
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
per the static issue:
did you unplug the RCA from your amp while the headunit was on while you were testing with the dd-1?
per the clipping at 30 issue:
Also, where are you checking your headunit from, the amp or right of the RCA cable?
damn I am done here have fun people there's the problem
If I did my wire leads like this to my HU my radio and everything else will be static as well the +/- are to close to each other
  • Who's Online   0 Members, 0 Anonymous, 1114 Guests (See full list)
