CZ702 Headunit Issues (static)
per the static issue:
did you unplug the RCA from your amp while the headunit was on while you were testing with the dd-1?
per the clipping at 30 issue:
Also, where are you checking your headunit from, the amp or right of the RCA cable?
Yes, all RCA's were unplugged from the amp when testing with the DD1 and I was checking the HU right from the RCA. I tested it on the RCA that went into the front right that was usually plugged into the amp.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
If I did my wire leads like this to my HU my radio and everything else will be static as well the +/- are to close to each other
Ive had all of my other radio install done the same way. Soldered and heat shrunk and never had an issue. Like Orion said it is shielded so thats not the issue or I would have noticed it on my previous radio.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Alright Ill double check all settings.
BTW thanks for all of the help guys, I appreciate it.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
damn I am done here have fun people there's the problem
not sure if serious or not...
that is exactly how I do any headunit I install, solder with heat shrink. never had an issue, since you know, it's a correct way to do it any all.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Ohh no hahaha. Its the black heat shrink around it thats making look like it does. No its not pinched or going through that hole lol.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
This is a better picture.
DF990F88-E271-4383-9F2C-B9C6D3BC1342_zps
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 975 Guests (See full list)
