Figured I start my build log here on SMD. It's funny that this all started over a yr ago, planning to run DSS Ethos, and BC3500, and C1100.4, single 280a alt, and 2 kinetiks. then it all got traded around to this:
Pioneer AVH 5600
2 Tantric HDD 18's
1 BC 5500
2 RE XXX 6.5 comp sets
1 S800.4
4 HC1800 Kinetik's
1 Dual alt kit
1 350A Singer along with stock unit
Head Unit was first-
dang radio wouldnt fit due to the rear bracket- so..
Bracket removed-
Radio back in
01 Suburban Z71 - 5.3L - Black - 6" Lift on 35's - Pioneer H/U - Kicker Mids, 8" Polk sub.
Past rides-
07 Avalanche - Sunburst Orange - 4/6 Drop - Pioneer AVH-X5600 - 2/0 Royal Excelene - T/M fuse blocks - Stock and Singer 350 Alts - 4 Kinetik 1800 - Crecsendo BC5500 & S800.4 amps - 2 Tantric HDD 18's.- RE XXX 6.5 comps
01 Grand Vitara - V6 - 4x4 - Pioneer H/U - Incriminator 6.5 Comps - SSA XCON 18 - Skar 1500.1 & 84.4 amps - Singer 160 Alternator - Optima Yellow top..
Built the box for the 15's-
The DSS's were a beastly set of subs
Painted face- Same color as the truck-
10330261_10152466019347938_9132623289059
Bedlined the rest
1512804_10152493829402938_21989816234949
Then after a few months- retrofitted foor the 18's.
Adjusted port. was 10 cubes @ 22hz- now 11.25 @ 32.
Finally loaded and in the truck
Started on my battery box- Buss Bars are from Ill Customs on F/B- tried to get TM but they never got back with me.
Past rides-
Then Amp Mounting under the rear seats-
TM Fuse blocks
Making connections
My son caught me working.LOL
5500 wired up partially
3 runs of 2/0 grounded to frame
Love the drains- perfect for this
280A Cande Shoppes Alt vs 350 A Singer- love that Singer charging post.
11151041_1077828495567169_47947967364594
Dual kit with stock and Singer
10985664_1077828605567158_36191093493599
11041812_1077828788900473_52188030042082
3 runs 2/0 ground up front
2 runs positive to the back bank
zinc coated and painted the grounds
oooh wee!
Alt pigtail
Past rides-
Installing Voltmeters- top is at radio, bottom at Bass Amp. Factory PCM only runs ~13v hot...suck. hence the dedicated Singer.
Clicked in and added some epoxy.
11057302_1086451438038208_33299274014032
FINALLY- this is where I am today. RCA's etc ran to the amp rack.
OK there you guys have it. Fire away....I'm tough.LOL
Past rides-
I don't see why you were worried about posting it man, looks great nice clean install.
Very nice work. Been keeping up with this on SSA
Pioneer 80PRS
4 Scan Speak discovery 4" full rage
2 Ampere Audio 6.5 Comp sets
3 Singer 370 Hairpin's
1 Odyssey g78/34-P1500
6 DieHard Platinum Marine g31
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Lots of welding lead & SkyHigh
Team DC AUDIO
Thanks guys.
Yeah, I have a full log on SSA. It has everything I done the first time- before I got laid off. Thought I was going to let the truck go back- so I pulled it all back out(It was all the underhood stuff) but I ended up keeping it. That's when I started trading around.
I am gonna go try to get a lil more done today. But have to run around this evening picking up my kids...Hope to atleast get the Singer charging.
Past rides-
