07 and up GM vehicles alternator questions
So I have a 08 escalade ext and I know that's the alt is pcm regulated. If I was to go with a Aftermarket alternator what would be a better option. Where it's pcm regulated or have the alt non pm regulated.. Cons or pros of each system? I tried looking for topics but I couldn't find it??
Stick with the PCM regulator unless you're competing or absolutely need to have 14.4 volts all of the time. The only advantage of using and external regulator is it keeps the alternator voltage at a constant level. The PCM is designed to lower the voltage when the battery doesn't need charging so as to save fuel consumption.
I'm running a Mechman 270 with the PCM regulator and I don't have any issues. The voltage does drop to the low 13s but that doesn't mean that its not producing enough amperage. As long as you have a few good batteries and keep them fully charged you'll be fine.
You can also talk to the guys as Missing Link Audio, they know all about these GM charging systems and can build you a specialty regulator.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
What he said ^^^
I remember my buddy got his Avy done years and years ago, like 6/7 years ago and DC power told him to get a MLA, been running like that for this long with zero issues.
I'll go ahead and add that he has a dual alt set up
Team Bass-Hz
I don't have a problem, '09 with pcm.
PCM basically does nothing when its cold and alt acts like a normal alt since the batts are cold. Only time I ever charge lower is when it's hot as balls out, and even then if you need it, turn the headlights on and usually that will force it back up to at leas 14-14.6v on my car.
Okay good stuff here wasn't too sure but guess I'll go with the pcm now to sell this other alternator lol
I agree with Baron of Bass. Add the dual alternator bracket. I have 07 Escalade. I added a dual with a 240 alternator and I am so happy with the setup. I don't have to worry about affecting the factory charging
You can also try to keep the voltage from dropping by shielding the batteries under the hood from the engine heat. Cool batteries means higher voltage. B)
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I want to do a dual Alt set up but later on in the future
why does everyone say stay pcm? b Because of the type of vehicle? I have a 06 mazdaspeed 6 thats normally pcm, but singer alts are the only company that makes one for my car. In my situation i bypassed the pcm, now it charges at 14.8 but goes down to 14.2 or slightly less when warm. I may talk to mike about getting a xs vcm.
  • Who's Online   0 Members, 0 Anonymous, 895 Guests (See full list)
