deadbroke Posted May 7, 2015 Report Posted May 7, 2015 does meade not fuse his alternator wires from the alternator, just at the buss bars in the back? to me it seems like he runs wires straight from the alternators to the buss bars in the back and I have no idea where he runs the negative wires that hook up to the buss bars. maybe someone can shed some light.
MrBigs63' Posted May 7, 2015 Report Posted May 7, 2015 Check out his build logs man. Tons of pictures.
Broke_Audio_Addict Posted May 7, 2015 Report Posted May 7, 2015 I do not believe that he fuses his alt runs in the front but he's been in the game a long time and knows what he's doing and he trust his whole install. Me I'm too scared for that nonsense. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
deadbroke Posted May 7, 2015 Author Report Posted May 7, 2015 I was looking through his video logs and that's when i noticed then looked through his build log and couldn't see anything showing more. I don't think he fuses at the alternator which seems pointless to me if the only fuse is at the buss bar. Im guessing he grounds the buss to the alternators even though i haven't seen a picture of it
Broke_Audio_Addict Posted May 7, 2015 Report Posted May 7, 2015 He knows what he is doing man don't worry. It hasn't burned down yet has it? And it's been completed and playing just fine for a long time now. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
deadbroke Posted May 7, 2015 Author Report Posted May 7, 2015 I was thinking of doing it as well but figured i would ask first
Broke_Audio_Addict Posted May 7, 2015 Report Posted May 7, 2015 Don't unless you're ok with the possibility Of your car burning to the ground. Just because you saw someone else do it doesn't mean you should too. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
OrionStang Posted May 7, 2015 Report Posted May 7, 2015 Some people fuse that run, others don't. If I was running front to back, I would. But I don't fuse the 2ft run from my alt to front battery. SMD Super Seller My Feedback Thread
Bump4life Posted May 7, 2015 Report Posted May 7, 2015 he probably has the runs from the alt to the back and only fuses at the rear if i recal right he has fuses from those runs. if they are not connected to a battery in the fron they only need to be fused on one end. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Broke_Audio_Addict Posted May 7, 2015 Report Posted May 7, 2015 he probably has the runs from the alt to the back and only fuses at the rear if i recal right he has fuses from those runs. if they are not connected to a battery in the fron they only need to be fused on one end.I'd still say they should be fuse at both ends because you want the fuse to be as close as possible to the potential issue so if there is a problem in the front and it's not fused you're gonna have a bad day.I fuse any positive wire I could care less if it's a foot long it's getting fused. Also alts can go nuts and having them fused can possibly prevent it from frying your stuff if it does. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
