Box flex issues/new design
Went out to my first comp today. The highest I hit was 139.9 on a 34 hz burp. I think there might have been some major flaws in my box design looking for suggestions for another box. I am not opposed to any suggestions at this point but due to trunk size the sub will have to face upward. Just looking to get a little louder.
Setup
05 Chevy Malibu
1 18 FI SP4
DC Audio 2k A3 (2000rms)
Sky High Big three (2/0) OFC
Sky High (1/0) OFC ran to back
XS D3400 (starting)
XP3000 (Rear)
Box (3/4 MDF)
Exterior
Height 15in, Width 38in, Depth 30in
Port 34hz (opening facing inside cabin on bottom of box) Height 2in, Width 36.5 in, Length 18 in
The top (sub holding side) was braced with another sheet of mdf 36.5 x 28.50
The port side was also braced the same way
The port itself had 2 3/4 x 3 in mdf "leg" supports in the rear
When I first played it I had about 1-3 inches of flex on bottom of the box which I was able to reduce by putting in multiple 3 inch lag bolts.
Your port had a really high aspect ratio (2:36.5), not the more efficient port shape. That layout does't make the box any stronger either, which is probably why you were having flex issues. Whatever you do next, I'd orient your port differently.
Builds:
I feel like I lost a lot of DB from the bottom flexing having no bracing at all (besides bottom to port). What about a setup like this with a port on one side facing in 3 common walls.
Exterior
Height 14 Width 38 depth 32
Port inner
Height 12.50 width 5 length 8.5
35.97hz 7.43 cubes after displacement (minus bracing to be determined)
Actually bracing with mdf vertically on the inside
yea bro the 18 is gonna be hard to make it work. switch to 12s or 15s. i also have a malibu. the only other way i could see this 18 working is in 4th order using your spare tire as the seal side and firing thru the rear deck or thru the fold down seats.
I am pretty much stuck for while until I could save up to get a 15 or 15's. I currently do have it firing through the fold down seats. As I lack the box building expertise (didnt brace current box) I haven't even attempted to look into a 4th order. Spare tire has been removed since box build though so its currently unused space.
Like others have said, you will have better luck switching out your 18" for something you don't have to have firing up. If you are going to go to the effort of rebuilding your box you might as well make what ever changes you need to to do things right. Otherwise you will just be trying to find the least detrimental way to do things incorrectly.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3001 Guests (See full list)
