deathcards Posted May 27, 2015 Report Posted May 27, 2015 http://www.ebay.com/itm/Precision-Power-SN-8-Sedona-600-Watts-8-Single-4-ohm-Car-Audio-Subwoofer-New-/151518903333?pt=LH_DefaultDomain_0&hash=item23473afc25&vxp=mtr SVC 4ohm, Fs of 47Hz http://www.ebay.com/itm/Kicker-8-Inch-Competition-Subwoofer-Stillwater-05C84-ORIGINAL-/261897877681?pt=LH_DefaultDomain_0&hash=item3cfa5478b1 SVC 4ohm, FS of 40Hz a few reviews for the ppi http://www.sonicelectronix.com/item_68772_Precision-Power-PPI-SN.8.html and all4spl is right just for extra backup clipping and distortion kill speakers not underpower skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Mike Gann Posted May 27, 2015 Author Report Posted May 27, 2015 I used several of those MCM 55-2421 subs. I've only used them in bass horns, but they should work OK for ported boxes. .6 cubes each tuned to 33 Hz should work reasonably well. I know those subs are pretty popular with folks looking to experiment for cheap. If you wanted to step up a notch in quality I'd go up to an Infinity 860W. I've used several of them as well and I think they are the best you can get in that price range. If you shop around you can probably get them for under $50. I actually have a box to that spec laying around that I made a while ago, .6cu @ 34.5hz but it's already made to fit a Sundown SA-8. Is there a reason you only placed them into horns, are they quiet? I was hoping to get someone to tear the specs apart with me, maybe I'm not seeing what's wrong with them. I see that the xmax is only 8mm and the Qms is 14. But the pros to me seem to be low Fs, low Qts, frequency response goes below 30hz, everything else seems pretty standard. Am I doing it wrong? My Ford Fiesta build log: http://www.fiestafaction.com/forums/threads/42371-Building-a-Fiesta-Sized-Subwoofer-Box
bighossf150 Posted May 27, 2015 Report Posted May 27, 2015 $30 budget? http://www.ebay.com/itm/like/281642843783?lpid=82&chn=ps Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
deathcards Posted May 27, 2015 Report Posted May 27, 2015 http://www.parts-express.com/grs-12sw-4-12-poly-cone-subwoofer-4-ohm--292-484 http://www.parts-express.com/dayton-audio-sd270a-88-10-dvc-subwoofer--295-486 skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Triticum Agricolam Posted May 27, 2015 Report Posted May 27, 2015 I actually have a box to that spec laying around that I made a while ago, .6cu @ 34.5hz but it's already made to fit a Sundown SA-8. Is there a reason you only placed them into horns, are they quiet? I was hoping to get someone to tear the specs apart with me, maybe I'm not seeing what's wrong with them. I see that the xmax is only 8mm and the Qms is 14. But the pros to me seem to be low Fs, low Qts, frequency response goes below 30hz, everything else seems pretty standard. Am I doing it wrong? There is nothing wrong with them. I just used them in horns because that's what I wanted to do. They work very well in that application. I have two loaded in a large tapped horn that knocks the shit out of my woodshop on a 250 watt plate amp. 8mm xmax is pretty darn good for a $30 sub. I think they are worth a try, especially since you already have a box that should work. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Mike Gann Posted May 27, 2015 Author Report Posted May 27, 2015 http://www.parts-express.com/grs-12sw-4-12-poly-cone-subwoofer-4-ohm--292-484 http://www.parts-express.com/dayton-audio-sd270a-88-10-dvc-subwoofer--295-486 I spotted those as well. I actually have a box to that spec laying around that I made a while ago, .6cu @ 34.5hz but it's already made to fit a Sundown SA-8. Is there a reason you only placed them into horns, are they quiet? I was hoping to get someone to tear the specs apart with me, maybe I'm not seeing what's wrong with them. I see that the xmax is only 8mm and the Qms is 14. But the pros to me seem to be low Fs, low Qts, frequency response goes below 30hz, everything else seems pretty standard. Am I doing it wrong? There is nothing wrong with them. I just used them in horns because that's what I wanted to do. They work very well in that application. I have two loaded in a large tapped horn that knocks the shit out of my woodshop on a 250 watt plate amp. 8mm xmax is pretty darn good for a $30 sub. I think they are worth a try, especially since you already have a box that should work. Yeah after all this, it makes me think I should just sell him my SA-8 and save us time. Since everyone seems to think 100w will run anything My Ford Fiesta build log: http://www.fiestafaction.com/forums/threads/42371-Building-a-Fiesta-Sized-Subwoofer-Box
