JakeMN Posted June 3, 2015 Report Posted June 3, 2015 Most reputable places will be $125 plus shipping to get it fixed, such as db-r and amp medics. It's only a $250 amp so good idea on not sending it in. Same burn marks on my sae-1000d and I actually sent that in and am waiting to hear from them and once I do I'll let you know what parts those are. It blew because he turned the gain up? Or because of low voltage? Bass head in training. Trying to learn everything I can. 2014 Dodge Dart GT Synergy Audio WFO 15.1 V2 (Prototype) Sundown X12
Mr DeeBeez Posted June 3, 2015 Author Report Posted June 3, 2015 His voltage was good. 13.0 lowest full tilt on half ohm. Thinks it blew because volume was turned up, and he flipped the switch to turn on the amp and it popped as soon as he turned on the switch. I think it was just the sudden burst of power it got. And that would be awesome. I can't find the part ANYWHERE! Know of any other part that would work? Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
rocking.that.eclipse Posted June 3, 2015 Report Posted June 3, 2015 I think that if you pop the part number from the MOSFETs into google you can get them really cheap. Usually stuff like that is less than a dollar apiece and the repair guy by me said that if one pops may as well do all the ones that are attached to that so may as well do all them lol
Wicks Posted June 3, 2015 Report Posted June 3, 2015 Cant find them? http://web2.cet-mos.com/PDF/CET-MOS/TO-220-263-N/P75N06.PDF http://cet-mos.com/ I don't seem them commonly available through the big distributors (Digi/Mouser) so you'd have to find a replacement based on the specs. That being said, I would be very careful just swapping parts on an amp like this. You could be compounding the issue by not fixing the root cause and allowing the amp to run again and induce even more damage, even fire. Somebody needs to determine why those FETs blew and that can be a difficult task even with the right troubleshooting equipment and schematics. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
bighossf150 Posted June 3, 2015 Report Posted June 3, 2015 Most reputable places will be $125 plus shipping to get it fixed, such as db-r and amp medics. It's only a $250 amp so good idea on not sending it in. Same burn marks on my sae-1000d and I actually sent that in and am waiting to hear from them and once I do I'll let you know what parts those are. It blew because he turned the gain up? Or because of low voltage? I can almost guarantee that if he tried to send that amp to dbr they would tell him that cheap Chinese amps aren't worth fixing and he should throw it away Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Mr DeeBeez Posted June 3, 2015 Author Report Posted June 3, 2015 I have already Said I know it's not worth sending in. And that I'm just trying to fix it because it was free, and I wanna give it a go. Just to see if I can. And I have no clue what I'm looking for when finding a different part. I have said I'm not going to be upset at all if it doesn't work, but just wanna try. Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
Ahmed Johnson Posted June 3, 2015 Report Posted June 3, 2015 I know a spot in Chicago that can fix it but it'll probably cost the same buying it new
Guest Posted June 3, 2015 Report Posted June 3, 2015 His voltage was good. 13.0 lowest full tilt on half ohm. Thinks it blew because volume was turned up, and he flipped the switch to turn on the amp and it popped as soon as he turned on the switch. I think it was just the sudden burst of power it got. And that would be awesome. I can't find the part ANYWHERE! Know of any other part that would work? the problem is he played that particular amp at .5ohm brazil amp + .5ohm = fire
Mr DeeBeez Posted June 3, 2015 Author Report Posted June 3, 2015 His voltage was good. 13.0 lowest full tilt on half ohm. Thinks it blew because volume was turned up, and he flipped the switch to turn on the amp and it popped as soon as he turned on the switch. I think it was just the sudden burst of power it got. And that would be awesome. I can't find the part ANYWHERE! Know of any other part that would work? the problem is he played that particular amp at .5ohm brazil amp + .5ohm = fire Lol yeah. Well it wasn't me that did it. I just got a free blown amp out of it that I was gonna try to fix and maybe make a couple bucks in the process. Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
James Gilk Posted June 3, 2015 Report Posted June 3, 2015 I buy my mosfets from digikey or ebay i dont generally need 1000 mosfets so i buy them from ebay. good rule of thumb if te mosfet blew so did the resistor following it... If the resistor blew and the mosfet looks good it probably isn't.. If i have an amp apart and i am replacing the mosfets i do all of them for that particular section of the amp (if the mosfets blow on just a single channel i replace all of them for both channles) there cheap enough like 100 resistors is usually like $2.50 and 50 mosfets is usually less ten $30
