Broke_Audio_Addict Posted June 14, 2015 Report Posted June 14, 2015 Another option would be to buy a component set and put the mid's in the doors and tweeter's in the dash. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Broke_Audio_Addict Posted June 14, 2015 Report Posted June 14, 2015 Aftermarket 4x6's don't like to fit in these dash's if you go 4x6 you're going to have trim some stuff on the driver side at the very least. Easiest thing to do is components with the mid in the door and tweeter in the dash honestly. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
SMF93 Posted June 14, 2015 Author Report Posted June 14, 2015 Read online that the depth is 2&3/16 Not sure if its right, i will check in a little bit and let you guys know
reedal Posted June 14, 2015 Report Posted June 14, 2015 I put 5 1/4s in my dash since 4x6 speakers are limited in selection, mines a blazer but both have the same dash. It actually wasn't very hard and was my first fiberglass project. I have never did any fiber glass work before if I went this route i would need a step by step list of how to do it There's plenty of videos on YouTube and this forum and probably others too. Mark from C.A.F. has a bunch, find his page on YouTube and go through his videos. Different vehicle(s) than yours, but same concept nonetheless. That's how I learned. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
sphinxbccp Posted June 14, 2015 Report Posted June 14, 2015 On my build log there's pretty much a step by step on how I made them, if you had any additional questions if be happy to help. Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more...
Broke_Audio_Addict Posted June 14, 2015 Report Posted June 14, 2015 Read online that the depth is 2&3/16 Not sure if its right, i will check in a little bit and let you guys know At the very least you will have to trim the top of the Guage cluster on the driver side. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
firebirdude Posted June 14, 2015 Report Posted June 14, 2015 Mounting depth is tough on the old Chevys. Even the 2 3/16" figure mentioned above sounds like a stretch to me. I've put the Pioneer G series in several and they fit, but it's close. They're cheap and effective. Mainly for customers just wanting something that's not blown. Nothing something I'd recommend to a friend or anything. ZERO chance you're going to fit those Infinity Kappas in without some modifications though. Obviously Sphinx's post would work, if you're up to the task. Option B would be to cut away the A/C ducting that limits your depth and then use duct tape to close up the duct so the air still flows through. It works fine and I've done it to give clearance for double-din head units. Very rare though. Should go without saying, but make sure the HPF is set on them. Whatever you put there isn't going to take sub-100Hz very well.
Guest Posted June 14, 2015 Report Posted June 14, 2015 Read online that the depth is 2&3/16 Not sure if its right, i will check in a little bit and let you guys know Assuming you will be running these speakers off headunit power... rockford fosgate punch 4x6 have only 1-7/8" depth http://www.sonicelectronix.com/item_19560_Rockford-Fosgate-Punch-P1462.html since you will have the speakers out put some deadener in there! http://www.sonicelectronix.com/item_3128_Dynamat-Xtreme-Speaker-Kit-10415.html
ToNasty Posted June 14, 2015 Report Posted June 14, 2015 Read online that the depth is 2&3/16 Not sure if its right, i will check in a little bit and let you guys know Assuming you will be running these speakers off headunit power... rockford fosgate punch 4x6 have only 1-7/8" depth http://www.sonicelectronix.com/item_19560_Rockford-Fosgate-Punch-P1462.html since you will have the speakers out put some deadener in there! http://www.sonicelectronix.com/item_3128_Dynamat-Xtreme-Speaker-Kit-10415.html Do you know what's under there? Nothing to even put deadener on besides the heater box ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
