Port area. what does it affect?
nice add kirlill007.
i was using wrong terminology. i learned something about nominal impedence :)
i guess in my argument i was referring to the dcr not nominal. but my thinking is the same. when its in the gap i can see wehre they get the average from. cool stuff.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Knew I wasn't crazy.
Krakin's Home Dipole Project
well, like i said..
from nominal.
It dont go down from there..
from nominal to dcr, sure.. my subs are one ohm coils but DCR at .7.
The graph isnt hard to see that from nominal load it dont go down, but dcr can....the graph on the nominal load doesnt go through to the left......and only goes UP.
It goes down from the nominal if you are playing around 25 Hz or lower on that graph.
I was saying the same..
thing is, is my subs dcr is .7, but a 1ohm coil
if someones dcr is one ohm..... then you still wont go lower... because their nominal is actually higher starting..
so if my dc resistance is .7
i wont fall below that right?
Correct.
Builds:
Some of you are absolutely scare with how much you know about this shit.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Yep.
Impedance consists of two parts, resistance and reactance. Resistance is your DCR which is always the same, well, at least its not directly affected by frequency. The reactance is the other part of impedance which basically represents the opposition to a change in voltage or current because of inductance or capacitance. In our case with speakers, its basically just the magnitude of inductance produced by the woofer's coil that affects our impedance. The magnitude of this inductance is a function of frequency. So, it is this reactance portion of the impedance that is responsible for what we call impedance rise or box rise in car audio.
Team NorthWestSPL
soooooo
like i said..
my dcr is .7
others DO read one ohm...
you will NOT drop below that... the dcr...
that was my point........ the dc sub your running, and reads 1ohm.. well that is dcr.... you wont drop below that
same as mine at .7...... the NOMINAL is the pink elephant, when power is applied...
again, just saying, and you CANT drop below that.
  • Who's Online   0 Members, 0 Anonymous, 1275 Guests (See full list)
