Jake Pichola Posted June 23, 2015 Report Posted June 23, 2015 so i was planning on getting a 240 amp mechman alt installed but today i was talking to someone at a shop thats done alot with car audio, and he was telling me i would be better off just getting a second battery in the trunk because its just a 2100 watt system. with the shorter run amd capacity of the battery, i would be able to run my system better than getting a new alt because the power would still be coming like 8 feet to the front. if i would get a battery instead it would be an xs power xp battery, so which one should i do?
Ahmed Johnson Posted June 23, 2015 Report Posted June 23, 2015 Alternator. I'd rather have a cheap agm in the back and a good alt over a stock alternator and a good battery in the back.
Broke_Audio_Addict Posted June 23, 2015 Report Posted June 23, 2015 Something needs to charge those batteries. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
SnowDrifter Posted June 23, 2015 Report Posted June 23, 2015 9 times out of 10 I'd say your dollar would be better spent on an alternator ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Verlaist Posted June 23, 2015 Report Posted June 23, 2015 Alternator, I cannot stress enough the importance of a strong charging systems. Most people look at voltage.... Amperage is what you need and batteries alone will not fix all of your issues. As stated above something needs to charge your batteries. Also remember an alt also runs the car too, so if your stock is say 100 amp subtract at least 40 for the car. A 2100 amp is wanting around 200 amps to be efficient as an example. 2002 Forester Alpine INE-W927HD, Hertz Mille Legend 3 way 2 DC Level 6's,Bit One Audio , Audison Voce Due and Quattro, 4 Twisted Sounds 3.5K, 8 G31 Batteries, DC Power XP 270 Alternator. All Sky High OFC wire.
Lbox88 Posted June 23, 2015 Report Posted June 23, 2015 How big is your stock alt as of right now? UBL | Build Log
sirhutson Posted June 23, 2015 Report Posted June 23, 2015 Alternator. I'd rather have a cheap agm in the back and a good alt over a stock alternator and a good battery in the back. Something needs to charge those batteries. 9 times out of 10 I'd say your dollar would be better spent on an alternator Get the alternator. Alternator, I cannot stress enough the importance of a strong charging systems. Most people look at voltage.... Amperage is what you need and batteries alone will not fix all of your issues. As stated above something needs to charge your batteries. Also remember an alt also runs the car too, so if your stock is say 100 amp subtract at least 40 for the car. A 2100 amp is wanting around 200 amps to be efficient as an example. Yes. boss 1200 and a ipod nano.
