mbdblue Posted July 2, 2015 Report Posted July 2, 2015 Probably have been asked already, but I didn't see it in search.... I've been seeing more and more box builds using "support or stiffening" walls inside that have designs and shapes cut out of them...not just your typical threaded rod or 2 inch dowel. I'm guessing it changes frequency and airspace in the box but how is it calculated? Can't use the full sheet dimension since it has pass thru holes in it...or does it have such little effect it doesn't matter? Guess you could subtract the dimensions of the cutouts from your airspace calculation... I was always taught the less obstruction you have inside the box, the better air flow will be, not to mention port noise. But it seems these are the exact opposite. Any insight would be cool since I'm considering trying it out...especially cuz it adds a cool effect through a plexi window AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Inetba Posted July 2, 2015 Report Posted July 2, 2015 You can't calculate everything, I know a lot of people make multiple test boxes or the start the port waaaaay too big and then make the port smaller as they tune up. Also some people just want a pretty box.
khinds94 Posted July 2, 2015 Report Posted July 2, 2015 If you want to have a strong box without taking up space using wooden dowels or threaded rod use fiberglass resin it works great for support. If your wondering how tuning is affected by bracing you just subtract the volume taken up by the brace which should increase the tuning. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
mrd6 Posted July 2, 2015 Report Posted July 2, 2015 Sounds like you are talking about window bracing? Yes, technically it obstructs air flow slightly but usually the gains you see from bracing far surpass the few tenths you might lose from the obstruction of air. It's all a matter of finding the perfect balance. If you want to calculate the displacement you'll just have to do the math. Paper tuning won't change with bracing except for any change in tuning due to airspace displacement. My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
Leo1103 Posted July 2, 2015 Report Posted July 2, 2015 Are you talking about box bracing? If so, like this? 2002 Honda CR-VAlpine 9887My BuildRebuilding... Second Skin Damp 4 DC XL 15's 2 DC 5ks Singer 320 amp 6 cap banksSky High wire 2 VM-1's OM-1 all under window line Team DC Audio Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.EDIT: Not in a JP kind of way. I thought I was going to die from all the jizz filling my ears.
mbdblue Posted July 2, 2015 Author Report Posted July 2, 2015 Are you talking about box bracing? If so, like this? Yep that's what I mean Leo....but sometimes it's a lot more panel and less cutout. Just weird to me how I feel airflow was always stressed and now it seems like its not a big deal. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
mrd6 Posted July 2, 2015 Report Posted July 2, 2015 ^I mean, airflow is still important. The braces should be cut out like that with large windows. It is important to round over the windows as well and generally design the brace for optimum air flow. If you've seen someone bracing with whole panels with tiny holes for windows they are fucking up lol My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
islandpride684 Posted July 2, 2015 Report Posted July 2, 2015 Try hometheatershack.com, they have a bracing calculator with round cutouts or square to figure out displacements if you plan on using them.... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Triticum Agricolam Posted July 3, 2015 Report Posted July 3, 2015 If you build your boxes in SketchUp it makes it very easy to find out how much volume the braces take up. Its a little work, but SketchUp fixes a lot of design problems before they happen. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
islandpride684 Posted July 3, 2015 Report Posted July 3, 2015 Try hometheatershack.com, they have a bracing calculator with round cutouts or square to figure out displacements if you plan on using them.... Try hometheatershack.com, they have a bracing calculator with round cutouts or square to figure out displacements if you plan on using them.... here is the link http://www.hometheatershack.com/forums/enclosure-volume-calculator/ Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
