doug118 Posted July 9, 2015 Report Posted July 9, 2015 This happened in the matter of a week. I have 2 batteries and this only happened on the ground of 1 battery. I have 4 frame grounds and none of the connections are loose. Battery rests at 12.94. Any ideas as to why it happened? 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/
Skullz Posted July 9, 2015 Report Posted July 9, 2015 Is the battery out gassing? I think that only happens when the gas mixes with water and causes the build up of corrosion on the negative posts. I may be wrong but i have not seen it happen on agm like i do on lead acid batteries. EDIT: Is the top of the battery cracked anywhere? 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
doug118 Posted July 9, 2015 Author Report Posted July 9, 2015 No cracks that I can see 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/
reedal Posted July 9, 2015 Report Posted July 9, 2015 Are copper bars on both bats or just that one? What brand buss bar is that? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Skullz Posted July 9, 2015 Report Posted July 9, 2015 Does the vehicle have a leak around were the battery sets at? Just looking at that copper bus bar shows it like something has spilled on it and caused it to corrode. i would pull the battery and really look it over for any possible signs of cracks in the outer case. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
doug118 Posted July 9, 2015 Author Report Posted July 9, 2015 There is a hole cut in my floor for the 8 runs of wire to come through but this battery is the one further away from the hole. I found a tinyyyyyyy pin hole in the corner but I'm not sure if it goes all the way through the plastic. I'm sure it does because that's just my luck 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/
reedal Posted July 9, 2015 Report Posted July 9, 2015 See if they will warranty it for you... SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
doug118 Posted July 9, 2015 Author Report Posted July 9, 2015 HA! I've never seen them actually warranty a battery for someone 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/
reedal Posted July 9, 2015 Report Posted July 9, 2015 Does that means it hurts to try though? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
