low fps on high end machine
Even on normal settings? Sounds like something else is wrong. Bad drivers maybe. Bad sector on hard drive?
Leaning on drivers more than the HDD. If there was a bad sector, the machine would just freeze.
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
Also is this fps drop ONLY with gta5?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I have the same problem on my pc. MSI 7870 gHz edition. Can't overclock without it crashing all drivers, losing connection to the game, getting banned for some reason. This in on BF4 and csgo. Took off the overclock and get good performance. Just did the compatibility thing and its working on stock speeds. But in kombuster i get much better performance overclocked and its stable over hours. But not it game. Any ideas? Also the ram thing can anyone help? 16 GB Dual channel 1866mhz but only running at half that speed. I'm just wondering on all this stuff also since noone seems to have a fix. I've seen mantle hates any OC.
Sorry for jumping in but I'm hoping someone can help because noone on the specific forums has a direct answer.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Need to check if you motherboard will handle stock 1866MHz. If so, go into the bios and up the speed to match it. Not sure if you can do that in AMD overdrive, afterburner, or whatever type of OC software.
When you OC, you're basically boosting the voltage on the components. So, in game, you might be pulling more and making it unstable. It's a combination of components though.
Try to get everything highest stock as possible then work from there.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
It says it will handle I think 2100 but bios is set but I'm getting exactly half speed from it. Is there a reason for that?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Handle 2100 stock? You usually have to manually set the stock speeds on a fresh install in bios. It's never optimized at the start.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
It handles it. I went in and set it for the 1866 I have. But its running at exactly 933 from what it shows. Does this have to do with the dual channelnpr anything?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
So, you set it to 1866, but you're showing 933? Where are you getting these readings from? Once you set it up in the bios, it should be set unless you had a failed overclock. Then, it would revert.
I think even the single channel memory motherboard are up there around 1600MHz stock. So, I don't think a single channel would limit you there.
I'd try to set it to 2100MHz if your RAM and the motherboard agree.
PM me your specs. Links to the parts would be nice too.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Use CPU-Z to get system readings, anything else is useless.
If you set 1866mhz in the bios and whatever program you're using is reading 933mhz then you're probably fine, just the program is reading incorrectly, but realistically the memory speed isnt the problem. In whatever your favorite GPU overclocking program is, set power limit to the max (+20 or +50 depending on your GPU bios usually).
Hammerdown... 1%
I remember something like this happening on my pc after an update and the I think super sampling or something to that effect where it tried to double the resolution vs the pixel count effectivly doubling it and puttin a big strain on games
Current build
300amp alt
(1) xs power d4800 up front
(1) Optima yellow top 34 out back
All 1/0 skyhigh car audio power and ground including big 3/4
(2) Hyphonics 2000.4
front doors 5.25" memphis mclass comps don't recall exact model#
future plans to run (2) pair 6-8" mids each front door.
rear ski port 6.75" Alpine Type X pro series running passive
rear doors factory 5.25" need better speakers.
(1) ? sub amp maybe sundown saz-4500d
(1) ? Subwoofer maybe team 15"
getting by with a db drive 2400.1 class ab amp thats doing a good 660ish
watts rms to single JL audio 13w6v2 @ 2ohms
box 2.86 cubes slot port 32hrz
def need way more batteries.
https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
