2 way active crossover
maybe i should go alttle deeper into what im doing. im doing three way components in the front that are Semi passive. (gladen aero 3 ways) Meaning the the Tweeter and the midrange are on a physical crossover. However the Midbass is not . Im assuming so you can feed it more power?
not sure so im doing two full range amps. sugguestions
So just the midbass is what you're concerned about?
You could actually get away with less power when running active,
Using a passive crossover waste's lots of power.
My answer still stands. There's also DSP's. I think kicker and maybe audio control sell active crossovers. Probably other companies too. But that's needless extra equipment and possible signal noise and distortion. Active capable head unit, amplifiers with built in high and low pass filters, and DSP's are the way to go for active. If you want to run active, you have to not use the crossover that comes with component sets, or the capacitor that is sometimes attached to tweeters to prevent low frequencies. The tweet and mid range are passively crossed over, while your mid bass are actively crossed via the filters on your amplifier being used to power them.
What is the goal with this?
  • Who's Online   1 Member, 0 Anonymous, 962 Guests (See full list)
